Makerpipe.com
Came upon this product. An inexpensive means to use EMT electrical pipe to make a structured framework . Top it off with a tarp or shrink wrap and it will more than likely last the winter and then some.
If used on the deck of a boat a means to secure it to the stanchions must be devised. Glass reinforced tape or clover clamps would serve that purpose .
Thanks for this site… I didn’t know about it even though I’ve used EMT to make various tarp frames for years. I’ve found 1/2" to be adequate if you’re using plastic tarp instead of canvas (it’s lighter), even when we’ve gotten well over a foot of heavy wet snow. I’ve found that the clear poly-reinforced tarps will last 3 years if you do a bit of patching after the second winter and have put foam sleeves over all the sharp bends and points . A pipe bender is a really good investment if you’re going this route.
Ditto Dan’s comment about the bender. Using a bracket at the ridge and bent pipe down to the gunwale saves buying as many brackets and is easier on the skin.
I have a couple that I used to construct various farm structures. ( HERE ) is a link to the benders I have. They are surprisingly accurate.
When I put up Soave’s cover I’ll take more photos… here is how pipe interacts with the gunwale. It’s taped with strapping tape to the lifeline, then a firring strips are used to keep the pipes from moving forward or aft. You can see the firring strip to the left of the installer. Once the firring is taped in place the structure is surprisingly rigid and strong.
Last fall Fairclough installed the cover since it was new… this year I’m insalling.
Rob…
Another method which I use is ‘Kover Klamps’ which allow me to secure directly to the stanchions. Reusable and strong - to be used with 3/4” emt.
Ahh to use the stanchion or not.
Almost as timeless as the mast up or down question.
Nonsuch decks are beefer than the decks other boats from the 80’s. But I carry too many memories of soggy decks that friends blamed on stanchions that flexed under snow load.
None of these were Nonsuch boats, but I still baby my stanchions.
I have had success using recycled shrink wrap sliced, wrapped around pipe and stanchion and then of course applying a heat gun.
Having the emt pipe parallel the stanchion in vertical direction and attaching the clamp low on that stanchion along with cross bracing for the longitudinal pipe runs makes the entire structure pretty self sustaining.
Knock wood - all our stanchions are secure and dry after all these years. To each his own.
When you oppose that same vertical angle , you impose stress on that stanchion and then the fun begins.
