I am considering installing a radar reflector on the mast of my NS30U. I currently use a foldable Davis relector and hoist it up using the flag halyard. I can see the benefits of a permanently installed reflector whereas I cruise the New England waters. I am interested in what other owners have done in this regard, What brand reflector is used and how is it attached to the mast?
Thank you Mark, Mike and Allen for your responses. I like the idea of the fixed mount on top of the forward end of the wishbone. The photo appears to have a 3/8" size bolt or threaded rod mounted to the front casting. At this point I am leaning toward a Tri Lens reflector because of Practical Sailor’s testing and recommendation.
I believe it is bolted through the forward wishbone casting (where the choker block is attached) . Been there since I bought the boat including through several hurricanes (up to 95 mph winds). Never had much reason to mess with it since I bought the boat in 1995.
A couple of years ago I had a discussion with a RCMP Marine Unit officer about the need for radar reflectors on a Nonsuch with aluminium mast and wishbone. His advise was that because the boats target was much bigger than any added reflector, additional non-active devices would not provide any added protection.
The below is from the Cruiser’s Form. It tends to agree with what I remember from my Navy experiences -
Sea Harbour Yacht Club
Oriental, NC
Speaking as someone from the foggy state of Maine with literally thousands of hours spent in the fog all I can say is YES!
Radar likes right angles and flat surfaces to reflect signal back. Rounded masts are not a good reflector. While many boats do show up without a reflector the target definition and target itself on screen is usually quite small and can be mistaken for a lobster pot or buoy or sea clutter. Make your boat show up on someone’s radar screen and definitely buy a reflector..
Oh never mind I’ll just show you. I took this photo a few months ago at my mooring during the set up and install of my new Garmin HD radar that replaced a Raytheon CRT unit.
The target labeled in red as “C-30” is a Catalina 30 with no radar reflector. The much bigger target labeled in green as “M-28” is a Morris 28 with a radar reflector. Hopefully seeing is believing…!
LOOK BIG!!
| This image has been resized. Click this bar to view the full image. The original image is sized %1%2 and weights %3. |
P.S. ANY reflector is better than no reflector! I have yet to see a boat with any reflector that I did not pick up on screen. I have come across many boats with no reflector that I never saw because the target returns were inconsistent or appeared a sea clutter..
I appreciate the many responses from the members. The screen print of Joe’s radar screen showing nearby boats with and without reflectors has convinced me of the value of a good reflector. I have decided to permanently mount a reflector to the forward end of the wishbone as Allen and Mike have discussed.
The best information I have found so far is a comprehensive study reported by Practical Sailor Magazine. If you are interested in reading this article published in the August 15, 2001 issue, I am allowed to share it with friends via email.
I am leaning toward the Tri-Lens reflector as recommended by Practical Sailor.
Tri-Lens Radar Reflector
The standard Tri-Lens reflector from Rozen- ûdal Associates outperforms our previously recommended reflector, Davis’ Echomaster, at about double the price.
