I wasn’t going to post this because, I’m embarrassed to have been this stupid, but here goes…
Background - This is my 3rd season with Soave. I pay the boatyard ( where Soave winters) to winterize Soave’s engine because it’s an easy box to check on the form and doesn’t cost much. Soave’s raw water flow has always been good. Her sea strainer is on the starboard side beyond her hot water tank ( hard to get to.).
I 'm not sure why, but assumed that winterization included checking for debris in the sea strainer. Bad assumption.
After the Rendezvous and seeing a number of boats experience cooling issues, I decided to check Soave’s raw water strainer. I checked, just for grins, since flow is good and weeds are not a problem in the area we sail. It is something I knew I hadn’t personally verified, and I didn’t expect to find a problem.
When I checked the strainer I discovered the basket was missing !
At some point, either prior to my purchasing, or perhaps as part of the annual winterization someone forgot to put the basket back in. Now that I know, I’ll replace the strainer and clean out the heat exchanger, replace the impeller, and do an extra thorough flush of the system.
The reason for posting is ; I was one of the approximately 50% of owners at the Rendezvous that have owned their boats for less than five years. Sea strainer is on the checklist posted on the INA website… I used the checklist, but I skipped the sea strainer because it is in the winterization section. Hopefully I’m the only new owner that was a little overwhelmed in their first couple years of ownership and paid others to take care of things I should have personally verified.
Fingers crossed I don’t have an crud stuck where I can’t get to lodged in Soave’s cooling system.
Moral of the story, new owners ought to ( I wish I had) lay eye’s on every inch of your boat to be confident that it is indeed seaworthy.
On Soave I’ve found numerous things that are easy to fix, and definitely worth fixing to prevent future headaches.
Fall is a good time for preventative maintenance.
Hope this helps someone… just like going to the Rendezvous and talking to the owners that experienced over-heating issues on the way to Greenport, prompted me to check out Soave’s entire cooling system.
Sail on,
Rob…
