Adjustable Wishbone Hanger Lines for Lowering the Boom
Brian,
I suspect the rig is forgiving enough that effects of minor differences in boom angle on performance might be hard to detect.
I think you’re right about the importance of getting it right to avoid stress on the hardware. I can certainly attest to a scary amount of bend I observed in a stainless fitting holding the turning block at the front end of my boom. It looked like it was there to work around wear in the shackle fastener hole in the original aluminum. (I now have it done with soft lashings, which solves the bend problem.)
I, too, have started to play more with the choker in different wind conditions and seen respectable impact. It illustrates that our boats are very easy to sail, but also very amenable to being sailed better. I personally like that I can have an enjoyable sail when I don’t feel like tweaking, and an enjoyable sail when I do. Like the Almond Joy vs. Mounds ad, sometimes I feel like a nut, sometimes I don’t.
John, there’s some good material at Practical-Sailor.com on Dyneema. UV wear is very sensitive to exposure. Boats in the Netherlands get 3-4 times the life out of dyneema than do boats in the Caribbean. Their current advice seems to be that, because of its strength for its size, you can compensate for the UV issue by going bigger. I.e., if you use at least the same size dyneema as the wire it replaces, that’ll last as long as wire. I understood the article as saying that, assuming ten years of use before replacement, UV will only eventually degrade the dyneema down to the same strength as the wire.
That said, if I was going to go forward with adjustable hanger lift lines, I’d probably want to buy dyneema or spectra with a polyester cover. This would also address the UV issues, and provide a sacrificial layer to warn of chafe.
If anyone’s thinking of doing this, you might want to take a look at the Nonsuch discount INA has arranged with RWRope.com (see MEMBERS SERVICES & DEALS under the MEMBERS tab on www.Nonsuch.org).
RWRope is currently selling 8mm (5/16th inch) Paraloc Shark line for $1.67/foot. Paraloc Shark is a Vectran-cored, polyester-cover line with a listed tensile strength of 6,809 lbs. in that diameter.
The cover is what’s called a kernmantle weave rather than the braiding we’re mostly used to. This is claimed to hold well in sheetstoppers. However, it can’t be spliced; you have to either tie knots or make eyes with seizings.
Sorry to be so late replying to this. A N30 in our club does have lines for dropping the wishbone and it is a royal PITA. You really need three people to do it, with two on the forward lines and one person adjusting lines in the cockpit. Usually about half an hour. The other three Nonsuches in the club do it differently. Two use a ladder. One guy does his 26 by himself. The halyard is used to lower the wishbone. I have two halyards and use one to hoist a bosun’s chair, the admiral insists on doing this, and one to raise/lower the wishbone. Generally about 10 minutes of no drama. I am on the winch mostly doing not very much.
Bruce Clark
Nonsuch, N30
Whitby YC, Ontario
