There is a very fine hairline crack extending from the back of the choker attachment point into the main body of the forward casting on Canatara’s wishbone (see photos). The crack as seen in the first photo is almost invisible without magnification. Canatara is co-owned by Rob Collie and myself, and we would appreciate any wise advice on the appropriate follow up.
The choker attachment point had been professionally rebuilt 3 years ago involving welding on the casting. The repair showed signs of failure after the first season and the choker has been lashed around the casting ever since. (The attachment point is no longer in use).
Just to be clear, Rob and I are both engineers though neither of us has metallurgy expertise. Having said that, I suspect that this is a stress crack caused by uneven heating of the casting during the repair. Mike Quill can get a new casting made for us for $3100.00 cdn but he doesn’t know how long it will take.
Our questions are as follows:
- Should the casting be replaced? If so how difficult is this. It appears to be held on with large Phillips head screws, however a brief torque test suggests these may be tightly seized. Will the screws then need to be drilled out?
- Can anyone tell me if my theory about the origin of the crack is correct? If it is a stress crack, am I correct in believing that the internal stress can be relieved by drilling a small hole (1/8") at the end of the crack to relieve the stress and thereby stop the cracking? Is it possible that this may be the only repair needed, or is it a potential stopgap until a new casting can be obtained?
- Has anyone ever heard of this casting failing? If it did fail under load, what might that look like?
- Any other thoughts?
Comments would be appreciated
Thanks in advance
Bill Kroes
Sail No 24, "Canatara ", Sarnia Yacht Club, lower Lake Huron
