Your question got me thinking and I found another picture that shows the davits bolted to the wood strip. So much for memory. It’s the pushpit base which is bolted through the plastic.
Lloyd: Not knowing where you live and how you use a bimini or dodger, it’s hard to comment. Here are some photos of mine. Having delivered and driven a lot of boats over the years, I’ve found this style to be the most useful and versatile.
Photo NS30U#3 shows us set up for racing. (takes 5 minutes to remove)
Photo NS30U Bimini shows the unit with dodger zipped in and the side panel snapped up for storage.
Photo NS30U Exten 002 & 004 shows the aft end
Photo NS30U Joe and Jeff shows the inside with the starboard flap down.
Photo NS30U Snubber 001 shows it without dodger installed allowing free flow of air when anchored (most important in the south)
The way the side supports are installed gives very easy access to the cockpit when boarding.
Thank you . I am trying to decide between a pemenat bimini And one that collapses. I like the way it looks when at anchor but the concerns you expresses are things I am thinking about
Thanks for the pictures Joe. Always wondered, looking at your previous racing pictures, how you handled the bimini ,( among a few other wonderings). Also, who made the bimini and support structure?
Carl Linkinhoker
NS26C 146 Break of Day
Great Sacandoga Lake, NY
Carl Linkinhoker
NS26C, 146, Break of Day
Mayfield, NewYork
Thanks for the new photo Jim. I thought it looked like your Davit frame was installed on top of the wood strip. Which brings up another question. I wonder do you know if that Davit frame base is just screwed into the wood strip or is actually bolted through with a backing plate underneath the deck? It looks like the push pit attachment point takes all of the horizontal stress and it might not be necessary for the base to be bolted through to a backing plate below deck. It would simplify installation if that were the case.
biankablog.blogspot.com
Mike,
My impression is that the big installation issue to consider for davits is that they form a signficant lever arm that’s trying to pry all of its attachments simultaneously both upwards and backwards diagonally. Acting on that lever is the weight of the dinghy, which in the worst case scenario could have accidentally filled with sea or rain water. At 8 lbs / cubic foot, how much weight could that add to a dinghy? Even a person grabbing a davit as they fall off a ladder or a swimstep could turn out to be a serious load considering their distance from the fulcrum.
Personally, I’d be very nervous about whether our pushpit installations are designed to take those kinds of loads in those directions.
Will their fastenings and backings hold? Will the tubing bend? I don’t know, but if it were my boat, I’d want to be sure before deciding to go for a less than maximum strength installation.
Solar Wind
Nonsuch 26C, #143
They were designed and made locally, Carl.
Thank you for the photos . Had not thought about the need for a boom extension .
Joe,
A question about snubber pic:
Is the standing end of sheet tied to becket on top of stand up swivel block?
View is blocked.
Converting my mainsheet and like what you’ve done - including snubber.
Brooks Bridges
NS22 OB #24 An B’ad
Cambridge MD
Brooks: The line (standing part) goes through and is tied to the snubber. Google “snubbers” to see how they work
