Disintegrating Tides Track on a 26u
My current Tides Track is disintegrating on my 26.
Note that the hoist is recorded at 41’ however found a link here where the owner states 43’.
An anyone clarify the length necessary?
If you look on the metal gate at the bottom of the track, you should find a serial number. Give that to the manufacturer and they may be able to duplicate what you’ve got exactly. The caveat is that it might be older than their records, but it’s easy and worth a try.
Excellent thought thank you. I’m off to the boat to measure the track width, that helps a lot.
~ Graham
With apologies for the junk that got included when I pasted the link, above is how to get the info on-line once you have the serial #.
If you have to re-measure it, their instructions are here:
I’ve had Tides sail track on multiple boats, and always been satisfied.
-- Bob
Yeah, if yours is trashed you will love the new one. My sail comes down in 1.5 seconds.
They were able to locate my specs based on the serial number, awesome and many thanks again.
41’6”
~ Graham
I believe there is a serial number I think on the stainless steel cap at the bottom of the track. If you can find it I believe that they will be able to duplicate it.
Contact Tides, they’re able to lookup the information for you
