Hi everyone,
I’m hoping the Nonsuch community might be able to help me out of a difficult situation.
Last year I purchased Early Gay, a 1985 Nonsuch 30 Ultra, and had her delivered from South Carolina to Stamford, Connecticut, in the fall. Unfortunately, engine problems have kept me at the dock for the entire 2026 boating season.
The boat has a 4-cylinder Westerbeke diesel with a Mitsubishi block. The engine was smoking, and I hired a local marine diesel mechanic who determined that it needed some fairly extensive work. Unfortunately, he became seriously ill before he could finish the job, leaving me with a partially reassembled engine.
Here’s where things stand:
The cylinder head was removed, rebuilt by a machine shop, and reinstalled with a new head gasket.
The injectors were cleaned and reinstalled.
The glow plugs were cleaned and reinstalled.
The mixing elbow was removed and cleaned but still needs to be reinstalled.
The valve cover and some other components still need to be reinstalled.
The engine has not yet been restarted or tested.
As far as I understand, most of the major work has been completed. What’s needed now is someone experienced with marine diesels who can inspect the work, finish reassembling the engine, and get it running again.
I’ve contacted numerous local marine mechanics and yards, but most haven’t returned my calls. Hinckley in Stamford has worked on the boat previously, but they’ve expressed understandable reluctance to take responsibility for another mechanic’s unfinished project.
I’ve proposed handling the work in two phases: first, a paid inspection, reassembly, and initial testing, with no expectation that the new mechanic guarantee the previous work. If additional problems are discovered, those would be addressed separately with a new estimate and authorization.
I’m looking for recommendations for a reliable marine diesel mechanic or boatyard willing to take on this kind of work in the Stamford/Fairfield County area.
The boat is currently at Schooner Cove in Stamford and cannot move under her own power. However, I already have towing service, so moving her to a nearby yard is an option.
There’s also a second complication. Stamford’s hurricane barrier is scheduled to close from April 15 until at least mid-July 2027, which would prevent me from getting the boat out of Schooner Cove during that period. Ideally, I’d like to move Early Gay to a yard or marina outside the barrier this fall, have the engine completed over the winter, and keep her there until Schooner Cove becomes accessible again.
I’m open to winter storage on land followed by spring dockage, or another arrangement that would let me use the boat next season.
After losing an entire summer, I’m anxious to get Early Gay back on the water and finally enjoy her.
If anyone knows a mechanic, yard, or marina that might be willing to help—or has dealt with a similar situation—I’d really appreciate your recommendations or introductions.
Thanks in advance for any help!
Earl Ott
Early Gay
