Prepping for demasting I started to expose the wedges which I assumed will be the original hardwood. I have already purchased Mike Quill’s plastic replacements and a boot for next year. Under the yards of electrical tape that the previous owner used as a boot I found what appeared to be 1” thick plastic/rubber compound, no wedges at all. I assumed this thick “plastic” was poured in place to seal the area atop of the wedges. Now on the clock as my mast team was waiting I though crap, I have to cut out this sealant. To my surprise after hacking at it with hammer and chisel for 10 minutes to no avail. I noticed this sealant ring creeping up the mast. So I started hammering upwards. Bingo, I found that my mast wedges with this “sealant cap” are one piece. As in a 1” thick seal cap with wedges tapered to slip in to the hole, one piece. So several taps up and bingo it was up and out of the deck ring.
I have not heard anyone else describe this sort of seal collar cap wedge combo in the blog and I wanted to share what I found. I personally think this all in one unit is brilliant and I will be trying to remove it from the mast when it gets cooler and maybe use it as a template for a 3D print for a replacement as one other NS36 owner had a bugger of at time getting his wedges out whilst crane side and I hope to avoid that in the future.
Terry and Clarise
Phoenix 30U #404
