NS30U Stuffing Box packing size
Despite a lot of encouragement to adopt a PSS drip less shaft seal, I have decided to stick with the traditional stuffing box packing for at least this rebuild.
After much effort, and following the advice of Joe Valinoti and others (thank you all), I succeeded in opening up the stuffing box. I now understand the construction (on Persistence, the packing goes in the nut, NOT in the box, as I had been led to believe by earlier research on the internet) – my problem is that the pieces of packing that I have removed are not easy to measure – they are either ¼ or 5/16, and I understand that it is important to match the size. Can other NS30U users with a 1” shaft and a V-drive (FWIW) pass along the packing size that they are using? I am leaning to Gore GFO packing – any other recommendations?
Thanks for all the help to date – it is appreciated.
Bill Baxter
Persistence NS30 #507
Kingston ON
I don’t remember the size offhand. I do recall to use three pieces with the openings staggered. If you have a manual for the boat, it is described as to the size and amount along with the process.
Sea Harbour Yacht Club
Oriental, NC
Our 30U, with a 1" shaft and v-drive takes 1/4" packing.
David Young
Bay Cat, 30U #402
Freeland/Suttons Bay, MI
Hi Bill,
I re-packed mine last spring and it is ¼”. I used 3 rounds of Teflon impregnated packing – be sure to stagger the butts. It needed one adjustment (tightening) after running and is now almost ‘dripless’ with shaft remaining cool.
Larry Jack
U30 #261 ‘Felina’
Thanks Larry (and to several others who replied) – I should have had the wit
to open the manual – there in section 55 is confirmation that Persistence
will need 2 rounds of 1/4” ‘telon impregnated asbestos’ (!)
which is what I seem to have extracted from the packing nut. The manual
also has a schematic of the shaft and all the bits, including the size of
the stern tube (1-3/4”) so it appears I can now obtain all I need and get to
work.
FWIW I pass along an excellent illustrated description of the repacking
process here <http://www.pbase.com/mainecruising/stuffing_box&gt; .
Bill Baxter
Kingston ON
I use permatex antiseize on the threads to make it easier to adjust and change in the future. The two wrenches that came with the boat worked once I got it loose. It took several runs to adjust it so it doesn’t leak execept under power and still remain cool.
John Ferrero
1985 NS30U Puffin
Huntington, NY
Thanks John – had been thinking of the next time as well – this has been
painful – I soaked the threads for a couple of weeks and then tapped a piece
of wood down on the wrench attached to the locknut – almost no throw is
possible in the @#$%^&* space, but the soaking helped and it loosened up. I
now am looking at the hose (which means pulling the shaft) and while the
shaft is out, checking it for trueness and also checking the cutless bearing
– what starts a ‘small’ job can quickly become a monster!
Bill Baxter
Kingston ON
