I need more 12V red LED pigtails for the electrical panel - these are BASS
p/n 175-1002-410 or equivalent. They simply push thru the panel. I would
appreciate (online?) sources from members.
I purchased LED replacements for my panel at Radio Shack several years ago. Don’t have the part number but if you take an old one in they should be able to fix you up.
The original panel lamps were not LED, but incandescent. They heat up
and the heat eventually destroys them. The LED panel lamps from Radio
Shack are cool and will last longer than the boat.
I have replaced with the Radio Shack LED versions and find them a great improvement. I have mixed colors for various purposes which I think can be helpful. They are available in red, green, yellow and perhaps something else. I have packages aboard if anyone would like me to check part numbers. I can get aboard most any weekday.
Fred Rachwitz
Concerto
NS 30 U 445
Harbor Springs MI
I need to replace some of my indicator lights on my panel that I recently discovered crumbling. I like the idea of using different colors for various functions. Naive question: is the NOVA panel on my 30U standard? And the recommended Radio Shack LEDs work in this?
