At the beginning of June, I hurt my shoulder grinding my halyard winch. Bursitis, plain and simple. It improved and my doc told me to find a “mechanical assist for winch grinding”. All of you guys gave me various insights into a “WinchRite” and a Milwaukee 28 volt drill with a Winch Bit. No one recommended a powered winch or a bigger winch. They would have bankrupted me, anyway, and I don’t like powered winches. I am in Toronto, using Canadian Monopoly money. The WinchRite costs $1300.00 up here, seems to average 4 years before a time-consuming and costly repair and produces around 1140 inch-pounds of torque. It does a fine job but…
The Milwaukee drill is heavy as all-get-out and big. It and the Winch Bit would cost around $900.00 up here. It produces almost the same amount of torque. I ended up with a hi-quality h-torque HILTI drill. It’s small, very well-warrantied, built totally for the trade and the whole she-bang cost me, with the Winch Bit, $500.00 up here. You purchase this stuff in a HILTI store. It produces 1062 inch-pounds of torque. It came with a 110 volt charger, a fully-adjustable handle and a “small” battery. I have used it 12 times and the battery still displays “FULL”. No recharges yet. It gets the new, stiff sail on my N22 up in 9 seconds, with a very TIGHT luff.
This drill is a pure drill - not an impact drill or a hammer drill - just a drill. BTW - This purchase gives me a wonderful drill as well as a winch grinder. and, it’s safe - it will stop upon meeting too much resistance and not spin around the winch.
The product is a HILTI SF 10W - A22.
Also, a buddy of mine welded me up a HUGE extension winch handle, giving me a 26" handle. Ungainly, yes, but wonderful when you need a hard, half-turn. The drill is called “The Enforcer” and the extension handle, “The Persuader”. These toys make a big difference to slightly older shoulders (and backs and necks).
Shall keep this in mind for a few years from now. Now if I can find something for that manual anchor winch…
Alan & Tracy
Corvus, NS30C #216
Ashbridges Bay, Toronto
Thanks for the pix. I am interested, and I appreciate your research.
If you have the time, I have a few questions that need answering. Perhaps you already have the answers to some of them, and I am sure Hilti can provide info too regarding charging.
What is the clearance you need above the winch? I sail with a dodger up all the time. It would be a pain to drop it to raise the sail.
In operation, I assume you need one hand to hold the drill handle attachment, one hand to tail. So if you sail alone as I do, the winch is operated by a lock switch on the trigger? Stopping it sounds as it might be a challenge.
I know you have not charged it yet, but… Do you think a modified sine wave inverter would charge it off the dock? Or only a true wave inverter? I cruise for weeks at a time and need to be independent of shore power.
Have you heard of anyone using this tool on a NS 30?
Thanks for any insights,
Bill Baxter
Persistence NS30 #507
Cruising the North Channel
I have been using a Sears Craftsman 29v drill for 4yrs. 480ftlb torque but putting it in reverse to get the2:1 advantage of the Barient halyard winch. The Swedish rubber tailer works well and leaves me with a hand free to clear any problems. I have a 12v charger and get some 4 sail raises per charge. The drill, 110v charger and inspection lamp combo cost $95 US. Get one before Sears goes “belly up”". (I use a Cunningham to tighten the luff).
Dick Lane
I too use the Sears Drill and Winchbit. Works great. Powerful enough to raise sail without damage to sail worrries. I just upgraded the battery to lithium Ion too.
Dick Lane
NS26c #35, Swoose.
– You received this message because you are subscribed to the Google Groups “INA Nonsuch Discussion Group” group. To unsubscribe from this group and stop receiving emails from it, send an email to . For more options, visit .
Interesting to see how many folks use drills and a Winch Bit. Just to clarify, the Craftsman Drill puts out 480 INCH POUNDS, not foot pounds. 480 foot pounds just might be enough to lift a car to the top of the mast. The HILTI drill puts out 1162 inch pounds of torque. But … in truth, it’s all about the WINCH. If it’s a multi-speed winch, it has WAY more mechanical advantage and, for sure, the Sears drill will do the job.
I use a very powerful drill as I have a Lewmar # 16 SINGLE-SPEED winch.
Bill Baxter - I’ll get you those measurements in a day or two when I’m down at the boat and answer your other questions real soon.
I found that the Sear’s 110v input charger would not accept a square wave inverter output so designed and built a low pass filter (bigger and heavier than the charger) only to find that Sear’s made a 12v input charger, ( I think I corresponded with Mike about it).
Dick Lane.
I too have gone the drill route with Winch Bit. I went with the Milwaukee Hole Hawg M18 right angle drill $299.00 (model 2707-20) from Home Depot. It needs a battery so they sold me their Mikwaukee Drill with battery (and bonus large battery) So for $438 CAD I have 2 new drills and 2 batteries. That price also put me in the pay back over 18 months, no interest program. I also built a styrofoam stand to support the drill and it works well on my Nonsuch 26U.
Ernie, I wonder if you have thought about getting a right-angle attachment for the drill? They are available and would allow you more leverage using he drill body.
A right-angle attachment for the Hilti costs over $400.00 in Canada. Tho, I’m sure that a cheaper one can be found (not a bad idea, actually … hmmmm). I don’t need one as the drill is light, I have the room and the ergonomics present absolutely no problem.
