I too have started to convert any florescent lights that fail to LED. But, my philosophy is “If it ain’t broke don’t fix it.” That said I too use the existing fixture and rewire them with LED lights, But, I also remove the dead ballasts. They are useless why carry around the extra weight no matter how small.
I also use Anderson connectors on the wires so I can replace them should they also fail (one has already) in the future
biankablog.blogspot.com
Hi All -
I took a somewhat different approach to replacing all of the florescent lights in my 30U…
The florescent fixtures were all in good shape, the lenses weren’t yellowed, and I knew that the wiring was going to be tight and hard to pull thru the headliner… but I really disliked the power consumption and harsh bluish light the fluorescents put out, not to mention the mosquitos they attract.
I bought LED bulbs (fluorescent style) from Marine Beam. I selected the ‘Warm White’ color, and they are warm white, not bluish or harsh. They are brighter than the old fluorescents and make it easy to see into the fridge, and the light in the head is now much more pleasing to view one’s reflection!
12" for all of the smaller fixtures, 18" for the one long fixture over the saloon table. Not inexpensive, but now that they are in place, well worth the price.
There is a bit of re-wiring needed with these - mainly the old florescent ballast needs to be cut out and a couple of wires re-connected, and the extra wires just need to be taped off. Marine Beam has a very clear an instructional video on their website, and once I figured out which wire corresponded to which in the video (the colors were a bit different) and then did the first unit, the others were all relatively quick and easy. And the fixture over the fridge hadn’t been working for the last season (I put in fluorescent bulbs I knew worked and still no joy), but when I cut out the ballast and put in the LEDs, presto! The fixture works!! so it was just a bad ballast, and the fixture didn’t need to be replaced.
The only ‘eh’ in all of this is that the bulbs for the 18" long fixture actually direct their beams sideways - the light strips face outward along the headliner when the bulbs are turned into place, but it doesn’t really make that much of a difference… and these bulbs seem slightly less warm than the 12" bulbs. Good thing is that I use this fixture the least.
Very happy with the results! No more harsh lighting, no more “please turn those lights off!!” they draw too much power - I do not have shore or solar power (yet)… only way to charge my batteries is run the engine… The boat was bright and cheery in the evenings on this last trip!
