Hi Chris,
I am going to add my two cents to this discussion… S/V CAKEWALK III was on a mooring ball for her first 18 years (Manhasset Bay). We (my father an I) sailed off, and onto, the mooring frequently. Though we had two on board, the sequence is the same and was hardly ever hurried. I have single handed CAKEWALK III for the last dozen years and have on many occasion sailed off of a mooring ball, and have motored onto a mooring ball countless times. I have anchored/un-anchored (no windlass) on many occasions using the method outlined below if the winds weren’t too strong.
The mainsheet must be free to run.
The choker should be eased, at least partially.
The helm should be ‘locked down’ with the rudder straight (fore/aft), but not too tight as you will need to get it free quickly. The rudder moving over hard to either side may be what is causing your sail to suddenly fill.
If the above steps are followed, the boat should stay into the wind and keep your boom over the center of the boat.
Even if she somehow drifts off-center, the loose mainsheet and choker should keep the sail headed up into the wind and prevent it from filling.
If all appears stable (and you are aligned with the other boats and not swinging) and you have already chosen your route (always to the aft of the boats adjacent to you - you will hardly ever be able to get past their bow and mooring ball - just too risky to try!) based on the wind direction, drop the mooring pennants
walk back to the helm
release the helm lock but keep the helm centered
and then start taking in the mainsheet (but don’t bring the sheet in tight - you should end up close to a reach/broad reach)
as the main begins to fill, fall-off/turn the helm to the direction you want the boat to go
The boat should have drifted back at least half a boat length by this time, and as the sail begins to fill and give you forward motion, you should have sufficient way and room to sail under/aft of the adjacent boat. As the boom will most likely be in a reach/broad reach be aware of the other boats that were aft of you to make sure you don’t clip them with your boom!
Once clear of the adjacent boat, you should be able to bring in more of the main and head further up, if that is the direction you want to go.
Once clear of the mooring field you can take the choker in the rest of the way.
If the wind is blowing rather hard I would turn the engine on, just as security in the event the extra power/maneuverability is needed.
Like anything, getting the hang of it will take practice, so do it several times when the winds are light, and with the engine on in neutral just in case, until you get the feel for it!
My father was a brilliant sailor and I was fortunate to learn from him… he could pick his way, under sail, through the mooring field when returning and judge the wind and the boat so well he would make his turn into the wind, bring the sail to luff dead center over the boat, and drift the boat right up to the pick-up stick almost always with the pick-up stick dead-centered in the bowsprit. I know there are many others in this group who can do this too, but I was always impressed by my dad’s abilities! But, if the wind was blowing hard, he would have the engine on, in neutral as a precaution.
The Nonsuch is a fantastic boat to single-hand and constantly amazes other sailors that she can be handled so easily by one person… but it takes some experimentation, patience, and plenty of practice, so sail as often as you can, and you will get it!!!
Enjoy!
S/V CAKEWALK III 30U 1987 430
