Trying to figure out which marine toilet manufacturers offer the best choice for my ultra - thinking about - sizes, floor bolts etc
If you are going to stick with a non-composting toilet I would strongly recommend a Blakes Lavac. They are simple, dependable and the pumping system is durable.
Peter Moodie
Nonsuch 30U Catalyst #366,
Sidney, BC/Winnipeg, MB
My vote would be the Raritan PHII. The handle can be mounted on either side. It is more money but also more robust than a Jabsco. The handle design has more leverage than the Jabsco. In 2000 (I know 20 years ago but not a lot has changed with regards to manual toilets) Practical Sailor pick it as the Best Buy over 8 other manual toilets.
La Reina 26C
Vancouver, B.C.
I second going for Blakes Lavac. Put one in BIANKA ten years ago and never regretted it. Simplicity and ease of maintenance make it a great upgrade IMO.
biankablog.blogspot.com
La Reina 26C
Vancouver, B.C.
has anyone gone the fresh water route?
I am shopping for an Ultra 30 at the moment, but I have experience with the fresh water aspect. I keep my Pearson 30 on Cayuga Lake in NY. The Marina has no flow. There is one way in/out, with no creeks feeding into the marina. After a year, the odor from flushing was enough to make one gag. I put a 7 gallon jug with a pump next to the toilet and we flush with that. Odor was gone in a month. It’s never going to be perfect, but it is much better.
Chuck Garbarino
Soon to be Nonsuch owner
FATE came with an electric fresh water flush head (Thetford Newport) when I bought her. Head itself was so-so but the fresh water flush was great. I’ve been wanting to replace the head but keep the fresh water flush. In fact, I had no options since the thru hull for the original water intake had been removed and glassed over. I just had the Raritan Fresh Head installed. It’s manual but uses fresh water for flushing. No experience with it yet but it has a good reputation. Will let you know. (I wanted to install the electric Raritan Elegance but couldn’t make it fit.)
Jim Cosgrove
FATE 30U #343
Galesville MD
I have a fresh water Dometic Vacu Flush on my 30U. Works great, no smells. As close to a land-based toilet I’ve seen.
I’m just in the process of chasing a small vacuum leak that causes it to run more than it should in between flushes. Just some rubber seals that are overdue for replacing.
NS30U #396 " Quickbeam"
I’ve been very happy with my cost effective Raritan PHII. Fits fine and is easily maintained.
Thanks for all the help - winter project for sure
I just use my shower hose to flush instead of the pedal on my W-C. Then pump as usual. Freshwater…from my tanks.
Ko Barrett
Little Wing #403 30U
Mayo, MD
