Westerbeke 21
Hello all,
After a winter of work we finally launched our new, to us, Nonsuch 26C. After motoring less than a mile to the mooring we discovered the shaft, (but not he engine) was very hot. The engine temp was also running at a steady 180 on the way and the engine purred nicely.
This Spring a local part time mechanic replaced the cutlass bearing, shaft and coupling, stuffing box and refurbished the prop. I am told the overheated shaft may be a problem with the stuffing box being too tight as there was no visible dripping or maybe the engine is slightly out of alignment with the shaft by 1/4 inch. We are going to try loosening the stuffing box nut a little and idle in reverse on mooring to see if that helps. In any event, I am having it towed in the harbor to the professional rigging company this week to have mast inspected and sail rigged and now have the engine given a professional going over. Wondering what I am in for. Any thoughts on the shaft heat and 180 running temperature would be gratefully appreciated. Thanks again for all your generous insight and input. This forum has been so very helpful.
Steve O’Malley
N26C #172 ANU
Marblehead MA
Owners Manual pages 57.1 thru 57.3, propeller Shaft Log. My Universal M 25 Xp is a 3 cylinder 23 HP in my 1989 26C. My running temp is 165. 180 may be ok, but I don’t know your thermostat rating. But, a strict word of caution -don’ t motor too far as a too tight of a stuffing box will ruin a transmission. The OM says a drop of water every few minutes while the shaft is turning is a box that is properly adjusted! Bob Horne, 1989 N26C, ENCORE, Pocasset, MA.
Too-tight stuffing box was going to be my guess too. My coolant temp on my W21 is typically 180, like yours.
Ed Cook
Chat-eau
N26c #173
Ed Cook
Chat-eau
N26c #173
Definitely loosen the stuffing box adjustment. Your boat should have come with the wrenches that fit the nuts. It’s better to have some water come in then none.
Thank you all for your advice. I will keep you posted on results after we loosen it. Apparently we used a new kind of packing.
Robert,
I could only find a 27 page westerbeke owners manual online. If your version is online and you could share would appreciate it. Thank you
Stuffing cord is now sold with Teflon and Teflon grease and there should be a little water flow
180 is the correct engine water temp for a W21.
Westerbeke manuals are available on line at
https://www.westerbeke.com/Category/W21/5399ADA1DAF73A26740BF619#techdocs
