With the goal of getting more people interested let me share why I am looking at lithium. If we don’t get a group of 25 to 30 interested the event would be cancelled.
On Aloki presently, I have two battery banks. Bank 1/starting battery is a single 105 amp hour firefly AGM. That bank is fine and won’t be replaced. Bank 2 / house bank is three Firefly AGM 105 Ahr or aprox 315 amp hour bank to draw on. This combination has worked very well for the last five or so years, but is starting to show its age. Time to either replace or upgrade. I thought about lithium in the past but discounted the idea because of the complexity and the less than sterling performance of earlier lithium type batteries. (did you know there are six types of lithium batteries - I didn’t.) Technology has definitely advanced the subject to where I think it is a viable and safe upgrade to my Nonsuch. A live aboard electrical engineer friend of mine has the system I’m projecting (with more lithium batteries) in use aboard his 55’ Amel over in the Mediterranean for two years now and is amazed at the performance.
So, after some research , I’ve concluded that Victron systems offers a reasonable and safe upgrade that offers a major improvement to Aloki’s house bank that would meet and exceed my needs. Victron batteries in particular have the highest safety record of ‘runaway battery’ issues. (basically, none) In speaking to my insurance carrier, ( you should as well) , adding Victron batteries to my boat will not void or alter my insurance coverage.
Basically, the start battery remains as an AGM battery. A Victron dc to dc charger is wired to that AGM battery which then charges the new lithium house battery bank. A monitoring device (standard or premium) is added as well as changing out a multiple selector battery switch. The battery charger remains the same but will only charge the AGM battery, not the lithium bank. That’s it. ( a bit simplified but accurate)
The goal on Aloki is less engine charging (the boat is on a mooring) and more service time for Refrigerator , heating, lights ,etc. On any diesel engine to electric motor conversion the lithium option makes a lot of sense. Couple Solar into the mix and one becomes quite self sufficient .
With my 100A alternator or 110VAC battery charger the charging cycle for lithium is reduced quite substantially. Longer battery life cycles, lower self discharge rates and weight reduction from three AGM / total 315 Ahrs @ 222 pounds to two LiPho /total 400 Ahr @ 90 pounds. Less weight and more amperage. There are quite a few other advantages but discussing them and your needs is the point of the event. Hope to see you at the workshop.regards, Gary /Aloki/Oyster Bay NY
