I’m going up my 1987 30U mast shortly, and think it’s a good time to replace my masthead incandescent lamp with an LED. The manual shows the lamp is an RZP-10-12 double contact indexed bayonette. I believe that a Dr. LED 8001757 model may be appropriate, but would like confirmation from someone who’s already done it before I purchase it and go up. Other makes/models to consider? Thanks for your thoughts.
Ive used dr led for masthead (anchor) and tricolor for several years.
They perform well
mark fagelman
Hi, I replaced my anchor light with a LED from West marine early last
year. Don't remember exactly which kind it was but it works fine and
is quite bright.
Vincent
I replaced my original AquaSignal anchor light unit with the identical
unit this Spring.
But replaced the bulb that came with the unit with a Dr. LED bulb that
was designated as appropriate for the particular AquaSignal unit.
Works great and the total investment (new AquaSignal unit and the Dr.
LED bulb combined) was just over $100, not the $2/$300 or more you see
for some LED units!!
CAKEWALK III 1987 30U 430
NY NY
