I am looking for the recommended clearance between the rudder shaft and the fiberglass tube it rotates in
The steering on my 26U had become very stiff over about the last two years. When I disconnected the wheel and tried turning the rudder with the emergency tiller I had to push hard with both hands. I have been injecting grease into the tube through the usual greasing hole, which has a fitting for a grease gun, The grease is the usual marine type. Has anyone else had this problem?
A couple of days ago I lowered the rudder to see what was going on.. It was surprising that we had to pull it down for most of the distance. Then I measured the shaft diameter and the inside diameter of the tube. The diameters were the same, or the tube was a slightly smaller diameter by a couple of thousands of an inch. In other words, the clearance between the shaft and the tube was zero or an interference fit! No wonder the rudder was hard to turn, and to pull down
I don’t know why this has happened. unless the grease has reacted with the fiberglass, making it swell. So now I will use an engine cylinder hone on the fiberglass tube to increase its inside diameter. I was thinking of about 10 thousands of an inch but would like to know what the original clearance was. I have been wandering about the marina waggling the rudders of other Nonsuches and the clearance seems to be about that amount.
For this work I have been using the main halyard winch to lower and raise the rudder. A line runs from the winch to a fitting screwed onto the top of the rudder shaft. The line makes a right angle turn in the top runner bearing, to go down to the rudder. I made a brass fitting to give the turn a smooth radius and coated the line with Teflon spray. The bits are shown in the photos.
John Barbour
Nature 26U
