Rudder very stiff to turn
Anyone ever experienced anything like this??
Put boat in water for season at boatyard. Motored/sailed to mooring - all normal with steering to include autopilot engage/disengage. Secured boat on mooring and frictioned wheel. Returned to boat a week later, took friction off and wheel extremely stiff to move in either direction - but will travel full length each way. Tightened and loosened friction multiple times, inspected cables - all on pulleys with appropriate tension. Visual inspection of rudder in water to look for entanglements or signs of damage or bent shaft. None noted. Engaged and disengaged auto pilot - working properly. Stumped…
Any ideas or personal experiences greatly appreciated
Cooper Hastings
NS30C “Bearcat”
Hi Cooper -
There are 2 spots to grease the wheel shaft bearings on the Edson wheel, under the compass. I had a similar feeling this Spring and it was solved by lubing them. You’ll need a small pointy injector tip to get the grease into the tiny holes, and rotate the wheel while injecting to get all the bearings covered.
Good luck,
NS30U #396 “Quickbeam”
Thanks Bob! Did your steering go from “totally free” to bound up after just one week sitting?? That’s my issue and my concern. Is it possible that the friction mechanism could get out of place and cause the binding? I also attempted to move with the emerg tiller - it was extremely difficult - but I have no prior experience with the tiller to compare.
Thanks!
Cooper
Hi Cooper -
I started this season with no issues, and then maybe after 4 outings I noticed a stiffness that I hadn’t noticed before. I had packed the rudder grease cup in the Fall, so I couldn’t imagine that was the issue. I had also oiled the cabling down below, and rechecked it to make sure nothing had happened since then. Last year I took the pedestal apart but I didn’t have a small enough tip to effectively get the grease into those holes. I did what I could at that time but I definitely didn’t get it into the holes like I did this Spring. Be careful not to overdo it either or the grease can end up on your brake. While you’re there you should grease the throttle and shifter joints, also small holes. I think those ones have screws covering them.
  • Bob
If you have a wheel pilot type autopilot check to see if it is not binding even when disengaged. Loosen the nut holding the wheel, sometimes that will cause the auto pilot wheel assembly to bind.
Try the emergency tiller.
Certain it is not the autopilot. Tried the emerg tiller - same resistance as in wheel. Boat sat thru a good blow, and I thought maybe during one or more if it’s violent “bobs” the rudder might have made contact with the ocean floor and bent the shaft, but it sits in 10 feet of water at mean low tide…
I had my steering apart years ago and can not recall if you can loosen the cable enough to take it off the quadrant enabling you to see if it is the wheel mechanism or the rudder. Is it making a noise at all? Putting a screwdriver end to the shaft and the handle to your ear while someone turns the wheel, you may hear the sound of friction. Doing the same to the binnacle housing would be another idea as that is where the other friction bearings rest.
The fact this happened suddenly and to such an extend makes me think it might not be grease or lubrication. Is the friction is equal throughout the rotation?
Physically detached the autohelm from the steering - piston on autohelm moves freely and rudder still binding. Tomorrow I will loosen both cables at the hub where they attach to the rudder shaft and move the rudder with the emerg tiller. If that is OK, I guess all that is left is the steering pedestal…
Cooper,
I was always taught that when things go wrong, look at the last thing that was done. You said ". . . Secured boat on mooring and frictioned wheel. Returned to boat a week later, took friction off and wheel extremely stiff to move . . . . " The last thing that was done before the steering was stiff was that you tightened the wheel friction. My bet is that the wheel friction is stuck, check that before you dig much deeper.
Tim in STL
White O’morn NS26U #216
Harbor Point Yacht Club
West Alton, MO
Exactly, Tim! Have loosened and tightened the friction knob numerous times (first thing I tried). When tightened, the rudder does not move at all and when loosened the rudder moves - with the binding mentioned. The friction knob spins freely at this point. I am not sure of the exact make up of the brake or friction device (I cannot find a diagram of it and have not disassembled it at this point) so I cannot make a judgement as to if it could be getting crossed up in there and causing the binding.
I have not gotten down below and had someone turn the wheel - I might be able to tell where the binding originates by comparing the tensions on the cables.
All ideas are helpful!!
This may help: https://edsonmarine.com/content/EB%20355-96%20689%20Brake%20Installation%20%26%20Maint%20Instructions.PDF
Tim in STL
West Alton, MO
Thanks, Tim!
Took it apart - brake functioning normally, chain on gear, cables in good condition and on all pulleys. Put emerg tiller on and could only move with my feet…
I think next move is a haul out and inspection…
Sounds like a lift is in order. You might want to climb into the stern to see if the quadrant is sitting on the top of the rudder post tub and gussets. If it is it will cause drag but not limit travel. This could happen if the reataing nut at the top of the rudder post has turned. It is supposed to be locked into place with two set screws ( I think it is two, might be one).
This sounds very strange. Could be a problem with the shaft but not likely because the shaft is quite sturdy.
If the quadrant was resting on the gussets you would hear a grinding rubbing noise.
There are two holes in the top nut each with a grub screw (also be careful there could be 2 grub screws in each hole). You may not see both holes at once, you have to turn the shaft to see the other hole.
My 2 bits. Ignore the following if you can see the top of the rudder when you look over the transom.
On this list in the past someone also had the same problem. Your boat was in a blow on a mooring. It can violently back up in this case and even with the rudder brake on it will swing to the max deflection. It was caused by the rudder swinging hard on the stop bolted to a gusset breaking it enough to go over the stop and ending up on the back side. The rudder then was jammed against the hull at a large angle and could not go back straight because the stop bolt on the quadrant was on the wrong side of the gusset stop.
Sorry I don’t have a photo. This is hard to describe but would be easy to see if you climbed down and looked at the quadrant.
26C 28
Penetang
If you haven’t inadvertently tightened your rudder friction I’d bet the rudder shaft is clogged with 40 years of accumulated goop.
I had the same problem last year.
The cure was to haul the boat, drop the rudder, saturate the rudder shaft with brake cleaner and scotch brite.
The marina had a gizmo similar to an engine cylinder hone . Do the same to your rudder shaft. Once it’s clean coat the shaft with new grease and reattach the steering mechanism.
If you do it yourself be careful not to damage the rudder shaft as I believe it’s fiberglass and not metal.
Dennis Gilligan
Coming in late on this subject but it might be that auto pilot was left in gear. Worth a look-see.
Butch
Butch Garren
Nonsuch 30, #196
Whiskers II,
Solomons, MD
One last trouble shooting to eliminate the pedestal would be to loosen the cables and drop them off the pulleys. Then check the emergency tiller to see if there’s any major change. Otherwise, Dennis’ solution is next for you.
All Great Ideas! Keep 'em coming!
Butch - I physically disconnected the autopilot from the system - no change
Although the steering has little play, I am feeling that play until the cable tightens and begins to move the rudder - then the resistance is felt
Bob - I have not loosened the cables - but that will be my next step - to completely rule out the pedestal
I have been down below and all “looks” normal, but all I have to go on in that regard are the drawings from the original manual
Dennis - the “40 years of gunk” makes perfect sense (since I have no idea when or if the assembly was every removed, cleaned and repacked) - but this was a sudden onset in that I drove the boat under power and sail from the storage facility to my mooring and all was perfectly normal. Fast forward 1 weeks later, and after a vicious N’Easter where my neighbors said the bow was leaping 5 feet out of the water, I board the boat and start to get ready to sail and the rudder is so tight I can hardly move it. As I said, sudden onset…
Depth at the mooring is 10 feet at Mean Low Tide and there was a super moon with corresponding larger tidal swings during that storm.
And, for what it is worth - I once looked at a NS30 and the owner told me that it had a bent rudder shaft - and it had the same feel as mine does now..
Local boat yard with a good rep and shipwright level experience has said they could look at it first week in Jul. No one else in the area was interested or had time…
I’ll keep you all posted…
When I was working on the rudder on La Reina and the quadrant was resting on the top of the rudder tube there was not any grinding sound when I turned the wheel slowly. When the rudder shaft was bent following contact with a log there were not any signs of damage around the rudder tube. When she was hauled there were not any impact marks on the rudder but something did not look right. When we took the rudder out the bend in the shaft was obvious. From the tip of the rudder post to the top of the glass there was 2.5” to 3” of deflection.
Mark powers
