I will be storing the boom from my 26C on board this winter and I hope to do the same on a friends 30U. Can anyone tell me how much the boom weighs on these boats? I’m thinking between 200 and 300 pounds, but I really don’t know.
I believe a 33 Wishbone is fabricated from 4” schedule 40 aluminum pipe. The two halves total about 58’ of pipe. The weight per foot is 3.730 pounds. Add 20 pounds for the end castings and you get around 215 pounds.
You can do a similar exercise on the other size boats.
Randy, I’m pretty sure the 26C boom is quite a bit less than 200 lbs. John Newell mentioned 140# in his boom change articles. I’m not sure where he got that but it sounds about right from practical experience. I was just lifting one the other day with one other guy and carried it 50’ and it was heavy but not that bad. I’m guessing my end was 60 - 70lbs.. Not very precise but I would have had trouble lifting more than 70 lbs.
The boom on my NS22 is a very easy carry for two old farts (pardon me) with bad backs. I don’t think my boom weighs more than 80 lbs (but it’s a 22, not a 26).
My wishbone with a Cressman s/s boom extension weighed 130 lbs. I estimate a standard 26 wishboom would weigh closer to 100 lbs. My 15.5’ x 4" round boom weighs 30 lbs. Hope this helps you estimate your weights Randy.
Mascouche 26C #1
