Butt Connectors for Stranded Wire
After 4 months of waiting on repairs, I finally got back my inverter/charger back. Wiring it back up uses #10 marine tinned stranded wire. Does anyone know where to find suitable butt connectors? I bought some like were on it originally, only to discover that those connectors were for solid wire and thus wrong from the get go. It seems stranded wire of the same gauge is slightly larger than solid wire. Does anyone know where to find suitable butt connectors for #10 stranded wire? I found some that looked like they would be perfect, but they don’t seem to come larger than #12 wire. I could probably make permanent crimped splices, but I like being able to take them apart if I should need to in the future. The ones in the attached pic look like they would be perfect but don’t seem to come in a size larger than #12.
Barry Clark
Swans Wing
NS 354, #71
Urbanna, VA
Try here: https://gregsmarinewiresupply.com/Heat-Shrink-Terminals
This is my “go to” guy for wiring supplies.
Tim in STL
White O’morn NS26U #216
Harbor Point Yacht Club
West Alton, MO
Anchor, cobra and Vertex all sell marine grade heat shrink butt connectors for multi strand wire.
Go with good shrink connectors and the appropriate crimpers for shrink connectors. They are the best possible and are easily cut and replaced if you ever need to. The name brands are expensive but there are excellent selections on Amazon for considerably less. I’ve used this brand and they are excellent. https://www.amazon.ca/dp/B01DOTB0XE/ref=redir_mobile_desktop?_encoding=UTF8&aaxitk=f7e426759ccc95d5fe7ea6807d017fb0&hsa_cr_id=3162870610301&pd_rd_plhdr=t&pd_rd_r=778c69b7-1630-41f0-a70d-ee10951cc822&pd_rd_w=L9Uf9&pd_rd_wg=8gN0h&ref_=sbx_be_s_sparkle_lsi4d_asin_1_img&th=1
