Companionway Doors for 30U
There is an ungainly collection of companionway boards on my 26C: the main teak-veneered plywood is in two pieces, upper and lower. I have two extra uppers: one is tinted acrylic and one a framed screen. These are stowed standing up against the inboard side of the galley counter. Here, they are all sandwiched together and held tight with a strong bungy cord. There is only 1 correct way to stow them so they fit close enough to allow the head door to swing open past them. For some reason I seem to be the only person who can do this (there is a subtle art to it). Have not been able to train any crew for this task. Frankly, I would like to reduce the number of panels as it is a bit of a hassle. Misty Cat’s wooden upper has a teak louvred and screened vent, which can be closed by sliding in an acrylic panel on the inside. It also has a hasp for the lock. The acrylic panel has no vent and no hasp. I’m thinking maybe I could vent and put a hasp on the acrylic panel and do away with the wooden upper - which is a perennial maintenance chore (varnish). And the light through the acrylic panel is very nice.
On my previous vessel, a gaff-rigged wooden catboat, there were a pair of swing open wooden doors which were lovely and handy (all the trim on this boat was native NS black locust). She had only 3 lines running to the cockpit and only a compass on the bulkhead, so when the doors were open it didn’t obscure anything. On the Nonsuch we have 3 instruments and 7 lines coiled on the cockpit facing bulkheads, I’m sure hinged doors would be a nuisance.
I’ve attached a pic of our old cat Queen Celeste showing the companionway doors. She is a Brewer 22 Cape Cod Catboat, built at Rose Bay Boatshop in Nova Scotia. I owned her from about 1987 - 2002.
Happy new year to all
Misty Cat N 26C #121
St. Peter’s, Cape Breton
Greg,
La Reina has two plywood drop boards. The top board sounds the same as the one you have described for Misty Cat, louvers and screen with acrylic panel to close it off and a hasp for a lock. On warm nights we would leave the board out and drape a mosquito net over the companionway entrance. I made a single piece drop board that I would put in for the winter so I could take the others home and put on a coat of varnish or two. Nesta made tow bags out of old sweatshirts to store the drop boards when we have them out. They are put on the quarter berth when not in use. Not a great location. I have and still am trying to figure out a better location. I have put in a second access door on the side of the galley so I can’t store the doors there. I have a water heater mounted on the back bulkhead of the the head so they won’t fit there. We have enough stuff in the forward central hanging locker to make it awkward to put them in there. I think they would be at risk of damage if I put them into the cockpit lockers so I have not even tried to see if they would fit in there.
Another option I have been considering is making L shaped slides that I can install on the overhead of the quarter berth. They would be installed so they taper in the same way as the companionway. A little foam on the top to stop the rattles and some slippery tape to make them slide in easy along with a latch to hold them in place. I would loose two to three inches of headroom over the berth so I have not made a commitment to the idea.
I also keep toying with the idea of swing doors for the companionway but the admiral is not keen on the idea so it has not gone any where.
La Reina 26C
Vancouver, B.C.
