Siva,
Ouch!!! Sorry to hear about your problems. Rough start with a new boat.
I’d suggest you see if the INA’s on-retainer advisor and former factory rigger, Mike Quill, has any advice. You can get to him via the www.Nonsuch.org website by opening the MEMBERS tab and clicking on MAINTENANCE.
A third alternative to the two you mentioned is to have a new rudder built. The specs for the rudder are on the www.Nonsuch.org website. Open the MEMBERS tab, click on NONSUCH SHOP DRAWINGS. Open the Nonsuch 26 collection and look for the ones titled, “Nonsuch26WheelSteering,” and “Nonsuch26RudderTop+SideView.”
You’ll also want to look at one drawing from the Nonsuch 30 shop drawings, titled, “N30 Rudder Fabrication.pdf.” That show the interior structure welded to the rudder post that’s sandwiched inside the fiberglass rudder itself. The dimensions of the rudder may be different, but the dimensions of this component of its interior are likely the same.
You can do a web search for outfits which build replacement rudders. The one I’ve heard of, although I have no experience with them myself, is Foss Foam: http://www.fossfoam.com/index.htm
I’m pretty sure there’s enough information in the drawings for them to supply you with a quote.
I don’t know how much a brand new rudder will cost, so I can’t promise that this is a viable alternative. However, if the price turned out to be acceptable to you, that would certainly ensure that you end up with a rudder that has no latent defects.
With the other alternatives, make sure you inspect whatever you get carefully before purchasing. You’ll want to make sure you’re not substituting one bent rudder for another, that there is no water being absorbed into the interior filling (e.g., if a small hole’s drilled near the bottom, does water weep out), and no signs of rust from the interior.
