Nonsuch Luck’s diesel lift pump seems to have died. The symptoms are the engine (W27A) starts normally and after a few second dies away slowly. Also I’ve changed the Racor filter on the bulkhead in the port lazarette and when the ignition switch is on the bowl doesn’t refill with diesel.
It’ll come as no surprise to any of you that Westerbeke want over $700 for a new pump. Has anyone had experience of a generic lift pump and what the specification of such a pump needs to be?
There are plenty of ‘solid state’ pumps on the Internet costing less than a hundred bucks.
Bob Illingworth
Nonsuch Luck 30U
Temporarily in Ipswich, UK; cruising the coast and rivers of Essex and Suffolk.
Hi Bob,
I had a similar problem on MagnifiCat, turned out to be several odd years of accumulated sludge in the fuel tank clogging the up take. As an Old Lutonian, I know a lot about accumulated sludge ! Pop in to Bury St. Eds. cemetery and put a few flowers on the family plot for me please, I’ll pay back at the next reunion. .
Regards,
Alan Steward
30C 144 MagnifiCat
Hi Bob,
I had a similar issue a few years ago on my W27A… part of the issue was that my batteries were old (8th season) and dying - check your battery output first! I changed the lift pump at the same time as I thought that may have been the problem as well (as I had pulled it apart somewhat to clean out the internal filter and may not have got it back together properly, though it had worked for a week or 2 before giving me problems…)
The mechanic who did the work (we were on a 2+ week trip and had to get towed into New London, CT) found a Facet (part of Puralator) Gold-Flo electric fuel lift pump which has worked well. Cost thru the marina was $249US (back in 2018) so direct from a supplier or Amazon I would venture today it would be maybe $150 to $200. Check the flow rate, etc to make sure you get a properly sized pump… I am not sure how wide of a range their pumps cover…
It was a very straight-forward install.
Image attached (from when I pulled my transmission to rebuild 2 years ago)
I had sludge in my fuel tank as well. I got a siphon hose and attached it to a wooden dowel so I could reach the corner of the tank after opening the fuel gauge port on the top of the tank. Pointing it at the bottom, forward corner where the fuel hose comes out I was able to suck out some nasty sludge.
I ended up draining the fuel tank, cleaning it as best as possible, and then refilling with fresh fuel.
Worth checking into that before buying a new fuel lift pump.
NS30U #396 “Quickbeam”
Another possible source of the problem may be a clogged filter in the lift pump itself.
These pumps can be opened to clean or replace the filter but I consider having a replacement gasket on hand before opening, assuming it has a gasket. My pump is not OEM and is installed so the opening is on the bottom which requires the pump to be detached at the hoses and inverted on a work bench to clean out the filter.
Ken Dakin
Sashay NS 33 #7
Kingston ON
My NS30U with Westerbeke 31HP engine, came with a separate lift pump mounted on bulkhead next to engine, installed by PO. I assume it replaced the non-working one attached to engine. It’s a Walbro FRB-13, 12v, 7 psi, costs about US$160. According to spec’s it has a 18,000 hr life, should be good for many years.
NAPA for $163. Just put one in my W27. It was in stock in my local store.
I do this every spring and never have a bad fuel problem.
It’s not a filter, but a strainer.
Do you have a make and model for that pump Joe?
Ron
Thanks for the hint. After five years on the hard, the new to me, Universal M35 started right right up today. However, I am certain draining the tank will be the smartest thing I can do. Now I have a plan!
Harry Bloom
Typhoon Harry NS30U #512
Thanks for all your thoughts and comments. I’ve had a quick look in the diesel tank and that’s clean, it was replaced about five years ago. The diesel I drained from the Racor filter was clean without any water in it. The batteries are good, they were renewed two years ago and are kept charged by solar panels. The lift pump makes a soft clicking noise when it’s running but it’s silent now so I’m thinking it’s either the pump or the wiring. I’ll get the yard to have look.
Alan,
Before I retired I used to work in the brewery in Bury St Edmunds and I drive past it between home in Cambridge and the Essex coast. I occasionally stop by to meet up with old colleagues so if I get the chance I’ll pop into the cemetery, the one by St Mary’s church to start with.
Bob Illingworth
Nonsuch Luck NS30U
Temporarily moored Ipswich, UK
Sorry, Ron. They just looked it up under Westerbeke W-27 and found it without a problem.
The lift pump can be easily checked by disconnecting the pump discharge line, putting a hose on it and placing the hose in a clear jar. You should see plenty of fuel coming out of the hose.
I strongly recommend cutting a 6” porthole into the tank which can be closed tight , but which allows for a thorough cleaning of the tank.
I’ve installed such ports in my N36, and in my previous boat (Wylie 34), and found the port to be very helpful.
barryConnell
Nocturne N36
There is also a fuel filter on the engine, just after the fuel lift pump. You checked the Racor, etc, but didn’t mention checking that filter too. It is easy to see in the photo posted earlier by Peter Grabow, it’s in the small metal cylinder just to the right of the new lift pump.
The pumps are made by Facet. If there is no clicking it is toast.
Ron
Part #301385 from Universal $246.80 - each USD
Torrensen also says a Facet 476459N same pump but cheaper
Facet Cylindrical 12v Fuel Pump, 1/8 NPT, 6-8 psi
https://www.pegasusautoracing.com/productdetails.asp?RecID=8118#
$117 USD + ship+tax
I couldn’t find an auto parts store that sold the Facet 476459N in Canada.
A Facet pump is $180 CAD from Princess auto(unknown Facet part#)
https://www.princessauto.com/en/12v-32-gpm-solid-state-posi-flo-fuel-pump/product/PA0008606279
It looks the same as the one in Peter’s photo above , it would probably work.
These “new” pumps are electronic in that they don’t have points like the original ones installed in our boats. I am not sure if this is a good or bad thing, the electronic pumps may be more sensitive to lightning.
26C#28 North Star
Penetang
Thanks for all your help and advice about the diesel lift pump on Nonsuch Luck. Being a stingy Yorkshireman I was determined not to have to spend a lot of money on a new pump. I went over the electrics very carefully and found a loose connection behind the instrument panel. Problem solved without any expenditure.
Bob Illingworth
Moored Ispwich but moving to Titchmarsh on the Walton Backwaters, Essex, UK; cruising the rivers of East Anglia, and, the North Sea.
Titchmarsh Marina, just off the Twizzle? Seems a long way from Yorkshire. Looks like a nice Marina.
