Engine access
All my days of boat ownership I have craved an engine easily accessed! Maybe even the tranny and shaft seal? What a dream!
Well this is not it! I will appreciate tips and tricks and mods that might make access easier. I’m dealing with a Yanmar 3 GM and need to replace the starter for starters.
Somewhere in there
How about a removable section of the cockpit floor?
Anyway all suggestions are appreciated.
Roger
Tranquility 30C #240
Port Aransas, TX
Of all the boats I’ve ever delivered or drove, the J36 was the easiest. It sat right in the middle of the main saloon.
![yanmar.jpg|320x240](upload://zkGqlKWIk6gCsJFo1TGspWZpvvL.jpeg)
I feel your anguish. I had enough boat Yoga working on the iron pig diesel in my 30U over the years. Pulled it out put in a LEMCO electric motor in 2008. Put in a 105 amp 48 volt Lithium battery last year. Now all maintenance is done from inside the cabin.
You might want to consider removing the engine and working on it on a proper work bench. Since you have a straight line shaft it should be easier to remove than the V-drive was on my 30U. Personally as I get older it’s all about comfort. :slight_smile:
My last boat was an older Jeanneau. It also had a yanmar 3gm. I loved that engine. I ended up cutting access ports around the engine. The other day I was looking at my 1980 30C. I believe I can cut an access port in both starboard and port quarter berths. Just be careful of any wires.
