I’m having trouble finding a source for 2 micron replacement filters for our original Racor fuel filter. Any sources will be appreciated.
Phil Harmeson
1985 NSU 30 Catharsis. #295
Traverse City, Michigan
Phil Harmeson
Phil - If your Racor is the primary fuel filter you will want to use a 10 micron. I’m assuming you also have the 2nd filter and 3rd filter on the lift pump. Using a 2 micron filter on the primary is choking the fuel flow to the engine.
Primary Fuel Filter w /1 gasket
Racor 2000SM – 10 micron
Secondary Fuel Filter w/2 gaskets
Westerbeke 30200
Sierra International 23-7770
Electric Fuel Lift Filter Kit – filter and rubber washer
Westerbeke 30548
NS30U #396 “Quickbeam”
The Rigging shop , Midwest dr , Toronto .
Bob Jenkins
Bob,
The previous owners of my 26C (W-21) and 30U ((W-27) used 2 micro Racor filters. I’ve continued their practice and know others that do likewise. Seems to work fine. Filter may clog earlier but very easy to change.
Jim Cosgrove
FATE 30U #343
Galesville MD
Yes, I suppose if you’re not having engine trouble it’s fine. Pun intended.
I never had fuel problems on Good News over 20 years . I attribute that to 2 micron filter replaced annually and a diesel additive with every time fuel was added .
Bob Jenkins
My fuel tank was pretty filthy when I first acquired it. I clogged up (2) 10 micron filters in one season. Drained the tank, rinsed it out, and then only put back in clean fuel. No problems since -
I’ve only used a 2 micron in my Racor since I got my boat in 2003 and never had a problem or symptoms of fuel starvation. The Racor part number is 2000SM-OR.
You can find them on eBay . I use 10 m , the Westerbeke lift pump and engine mounted filters are 30m
I believe the Westerbeke manual calls for the second or engine mounted filter to be 2 microns.
