Improving footing on the cabintop (Google Disc. Group cross-post)
I’m duplicating a post I just put up on the GDG to compare how it feels in both places. The post is… (the elves moved it to the Q&A category)
When I go up on the cabintop (mainly when it’s time to put away the sail), I frequently find myself slipping when the lines leading back to the cockpit roll under my feet. Often my foot slides down all the way to the grabrails before I catch myself. Both a fall risk and not good to be pushing the rails sideways with 200 lbs of me.
It might help if I could pull the lines taut, but since this is when I’m tidying up the sail, it’d be premature to do so.
I’m trying to think of modifications that would improve stability and security up there, and would appreciate any suggestions folks have. I’d also appreciate feedback on the options that have occurred to me, which are:
Build some kind of cover for the lines to run under, like a number of newer boats have designed-in. Pros: would solve the problem if the covers were suitable non-skidded. Cons: hard to build solid and make look good, risk of lines tangling and inaccessible to clearing.
Run some kind of “toerail” or foot bracing on the cabintop, outboard of the lines and inboard of the grabrails to catch my feet. Pros: easy to do with spare 1" x 1" PlasTeak that I have lots of from a previous project, potentially sturdy. Cons: not very aesthetic, need to make sure they don’t trap water, may or may not be sufficient.
Improve the cabintop non-skid so my feet catch sooner. I’m not sure non-skid paints would be sufficient given the cabintop curvature. So this would probably entail putting either one of the synthetic wood deckings like Marine Dek, or installing Treadmaster. Pros: would definitely increase security, and the synthetics can look very good. Cons: expensive, add weight, and would rule out Treadmaster if I care about looks.
Advice, please?
Regarding the test… I looked at posts in both GG and Discourse. I found the post in GG to be easier to read and understand. Possibly due to the way it is formatted.
Regarding your question, I haven’t noted the same problem on Soave. Maybe the slope of our cabin top is less or there are more places to step. I have a spare line that I use to secure the boom to one side of center. Maybe you could pick a place for your boom that would make it easier to walk on the cabin top ?
It looks like Bob put the text at the beginning of the three possible solutions paragraphs in bold in the GG posting.
(BTW - the font size your the Discourse site can be changed in the User Preferences area.)
I refinished my cabin top and decks with Alexseal paint. While the first coat was still wet I applied plastic “sand” to the finish. After this coat dried I swept up the excess granules, then applied two more top coats. The result is a very grippy surface.
While this does not solve the problem of rolling lines it does make for sure footing.
Randy Gadikian
Phoenix Rising
Nonsuch 26c #37
This topic was automatically closed after 309 days. New replies are no longer allowed.
