I could use advice on installing a Murray Cressman boom extension on my boat. Cressman is long gone, but there are still a few of these floating around.
This slips over the existing aft boom end and fastens by re-using 14 bolt holes on the original installation – six on each side, plus two aft. The aft holes are in the lower flange of the boom end, corresponding to the two bolts you’ll see in the middle of the picture above. They’re currently used for the padeye where the upper mainsheet block attaches. Two months of soaking the the fasteners with Liquid Wrench, plus a power impact driver, have almost freed the side bolts. That looks like it’s under control.
However, as you can see from these front and back pictures of the padeye, its fasteners appear to have been screwed into the aluminum rather than throughbolted. Forty years of corrosion has done its work. The padeye appears to be an imperfect fit, with something between it and the aluminum base. I can’t tell whether that was once an adapter plate that’s deteriorated, or corroded metal where the boom end met the padeye, or what.
With that background, my questions are:
How would that padeye originally have been fastened? What’s the best approach to removing it without damaging the boom end? In desperation, I could imagine running an angle grinder behind the padeye to cut it off, then grinding the area flat. After that, I’d try drilling differently placed holes through the stainless extension and the aluminum flange. Does that make sense, or is there no alternative to trying to drill out the existing seized screws?
I’d like to retain the ability to reinstall a padeye in case I later want to remove the extension, but I’m wondering if that’s hopeless.
For the six holes on each side where the boom end piece is attached to the two boom tubes, the forwardmost top and bottom holes seem to have a single long throughbolt. The remaining four appear to be 3/4" long 1/4"x20 thread machine screws. Is there a reason for that vertical throughbolt, or could that be replaced with machine screws as well for ease of future disassembly/reassembly?
Since a large surface area of stainless extension and aluminum boom and casting will be in contact, I assume I should be worrying about how to provide insulation between them. What’s your advice about how best to do that?
