The bottom looks good on Soave after a seasons use. I hope my bottom paint held up as well. I just finished decommissioning yesterday and will be hauled soon. I noticed your boom still up. Do you plan on lowering it to the deck before covering it this winter?
Hi Brian,
We bought Soave in the fall of '23 and she wintered in Westbrook with both her mast and wishbone up. ( HERE ) is a photo.
During our second winter she wintered at Norwalk Cove with mast down and wishbone rigged similar to the way yours is rigged in the photo. With the wishbone down the shrink wrap could protect the wishbone.
Last winter with the mast and wishbone down, I discovered minor corrosion, and after talking to a few owners that experienced mast failures, I decided to double down and remediate as much corrosion as possible and do better inspections of both mast and wishbone going forward.
The photo from this year was immediately after hauling, the rigging crew hadn’t gotten to do their bit yet. I’m going to winter again at Norwalk Cove with the mast down. This winter I’m replacing the mast fairlead collar and replacing the stainless bands at the base of the sail track. I may also add a second halyard. On a “mature” boat maintenance is never done.
I’m also using a canvas cover this winter instead of shrinkwrap.
