Anyone ever installed additional transom pad eyes or towing loops? I am constantly securing my Nonsuch 33 for storms and hurricanes and go with the philosophy of every rope I own and finally my shoe laces! My problem is attachment points for a storm that could swing 360 degrees. I thought i would install some large U-bolt type towing eyes on either side of the transom for some attachment points that were really easy with shackles. When i climbed under to inspect i was quite suprised to see sun shine coming through the transom! Apparently its quite thin. With proper load displacement (large backing plates) it might be okay. Just wanted to connect with collective expertise in this phenomenal group! Should i risk pulling of the transom?
Your thoughts and recommendations much appreciated.
I think the problem is in the direction of pull. You’d have to have rather large backing plates to absorb the load. You might be better off increasing the size of the deck cleats. Fortunately Nonsuches have a wonderful device called a “Sampson Post” forward.
FWIW, Practical Sailor recently had an article in which they suggested using dyneema loops with chafe guards on the deck cleats to create room for more docklines than could attach to the cleats themselves. Then attach the extra lines to those loops.
Sounds like a lot more time to tie up when you might be busy docking. Also, my concern is tying a knot that will come apart easily when undocking. Of course, I am a terrible knot tier!!
Rubber snubbers will reduce the shock loading with causes much of the damage. Line stretch helps, too large a line will not stretch as much . 1/2 dock line has a 6000 lb breaking strength well over the wind loads. Chafe guards should allow water to penetrate as it will help cool the line.
I have a small Boungy snubber on my main sheet and even it’s small range eliminates the slamming that can occur .
Been through thunderstorms at anchor but never the chaos of a hurricane at anchor or at the dock. Can’t imagine how never racking it must be.
hi thor, thanks for the tips! weirdly heat frictions got me before! but i think it was pressure based. am trying to upload access to some videos i collect. sorry to the rest of the group for the unnecessary or or unwarranted intrusion. tim
