Brian Cayer
Deep River, CT
I installed a
Groco safety seacock converter immediately after the raw water inlet.
I just winterized by closing the Seacock, pulling the plug on the converter and pouring in antifreeze through a hose attached to the converter.
Sea Horse
N26c in Maryland
I have the same strainer but do not know the make.
I drain the water from the sea side of the cooling system rather than deal with antifreeze.
My procedure is to dump the strainer, open the raw water pump cover, drain the heat exchanger, drain the muffler, drain any hoses with low pockets.
If you take the end cap(s) off off the heat exchanger to drain it then, you have had a look see at the pump impeller and inside of the heat exchanger.
Perhaps you will have found something to deal with before spring rather than to find it at an inconvenient time after the boat is launched next spring.
N33 #8 Margery
Niantic Bay, CT
I believe it’s a Groco older version of an ARG raw water strainer.
I winterize by taking the hose to the strainer off at the seacock and put it in a five gallon bucket of fresh water and run the engine. When the bucket gets really close to empty I dump two gallons of antifreeze in it and run the engine until the exhaust water is pink.
Bill M.
NS30U #335
Summer Song,
Mystic, CT
At some point we put a section of garden hose into a bucket of antifreeze and held the other end directly into the through hull fitting (from the outside). The pump sucked that antifreeze through the engine in less than a minute. No fuss. In the spring we do the same with fresh water. The hose seals well in the the through hull fitting with the hose fitting cut off.
Bill Kroes
NS 36 #24
Canatara
Sarnia ontario
Brian - Here’s what’s on my 30U #396.
NS30U #396 “Quickbeam”
Groco ARG-500.pdf (294 KB)
As you can see in the photo, I have an inlet to the system and just connect a hose to flush it and then place the hose in a bucket and it sucks the anti-freeze through the system. It is also a back-up emergency bilge pump. By the way, I strongly advise you to get rid of any 90 deg turns as they tend to clog.
Thanks to all for the input.
Brian Cayer
Deep River, CT
