Ouch ! What hitting a rock at 5 knots looks like
I hit a rock last Sunday on the way for our winter haul out.
My mistake, cut the corner too close at Peck Light.
Lesson learned, and happy the damage is easily repaired. I was expecting much worse. Nonsuch boats are tough !
On the bright side, the impact revealed that our hot water tank was mounted on a piece of rotted plywood… so I can replace the wood over the winter.
Bottom looks good. My keel joint repair from two years ago is still looking great.
Sail on,
Rob…
I’m gonna start calling you lucky Rob. Looks like a direct hit.
You need to take a close look at the hull area just above the keel stub for spider cracks and fractures in the fiberglass. Both the forward and aft ends above the stub. This is usually where the most damage is done because the stub is pulled down at the leading edge, and compressed at the trailing edge, on impact. While the keel itself may only have some minor cosmetic damage. Also look at same areas in the bilge. This of course all depends on how fast you were going when you hit the rock.
Hi Don,
You mean where the stub meets the hull… correct ? Since this would be visible from both inside and outside. Probably where the glass starts to get thinner?
So far I haven’t found any damage to the hull or stub. Will continue looking.
Speed was 5 knots.
Rob,
Yes, see red circled areas in attached photo. If you were going 5 knots and hit a rock, did you come to a sudden dead stop? Anyone standing up would likely have fallen over. If so, I’d be surprised that there wasn’t more damage than a nick in the lower keel. However if it was just a glancing blow without the boat stopping, you might have gotten off lucky.
Pays to take a very close look under the floor as soon as possible as if there is an issue you need to call the insurance company ASAP.
Had a freind get denied when he waited 5 months to check for damage after a grounding.
Had a friend who had an early 30C and he hit a rock in the North Channel of Lake Huron at 6+ knots. Very similar damage. In addition he had separation between the galley unit and the half bulkhead just forward. What happened was the keel was pushed up at the back briefly deforming the hull. It went back into place immediately and was easily fixed, new screws and plugs.
Hi Bruce,
The thing that puzzles me is that I haven’t been able to find any evidence of damage ( besides the keel as pictured ).
I would have expected to see evidence from flexing in the bottom paint and fairing layers. Also inside where bulkheads are tabbed to the hull.
The only damage I’ve found so far is that the hot water tank was mounted on some plywood that had rotted where the tank lag bolts were added. A couple of the lag bolts pulled out when we collided with the rock.
I’m planning to get on the keel repair before it gets too cold for epoxy. I can use my experience from repairing the keel joint a few years ago. I’ve very pleased with how well the epoxy bonded to the lead.
Remounting the tank is a little more complicated. When I pull the tank I’ll have easy access to some things I might want to relocate. I also see an opportunity to maybe mount the tank a bit lower. Lots to think about.
Rob…
As you remove things, you may find inspection opportunities that reveal any previously hidden problems. But, that shouldn’t add much time to your program. Hope it all goes smoothly.
-- Bob
