PAR Jabsco shower pump Model 3705=0000
Has anyone replaced this original pump with another pump since it is no longer manufactured?
Marilyn on Prelude, 30U, Little Current, CA
This is the pump for the shower on our 30U.Has anyone replaced it?
It is a Jabsco 37205-0000 that is no longer manufactured.
Marilyn on Prelude, 30U, 1985, Little Current, Ontario, CA
Hi Marilyn,
I have not replaced mine, however I think if you look at the specs on the side of the pump or Google the model number, you can then look for a current model with same or similar specs. That would be a 12vdc and flow rate. You could also send an email to Jabsco.
