Hello
The foot pump, white, under the sink is leaking when i press the pedal.
Is there any kit to fix that or an alternate place to purchase a new one
When I replaced the foot pump on my previous Nonsuch 26 in 2018, the replacement was a Whale Gusher Mark 3.
The original model is out of production. I can’t remember if I replaced vs. overhauled because that meant there was no kit or whether it was because the overhaul looked too complicated.
I vaguely recall that there may be versions with the foot pedal on left or right side of the pump. If it’s installed in a tight place, you might want to check this on yours before ordering.
I don’t know if this will help or not but the same leak was happening to me when I tried to use my foot pump on my 1987 30U. I then discovered that there was a rubber plug in the unbend aluminum spigot flowing into the galley sink. I removed it and it pumped out the refrigerator quite well, with no more leak below the sink.
