A comment from Ernie to my previous post (sail data) made me realise that I haven’t supplied you girls and guys with images of the progress made last summer.
As some of you may remember: a spray paint job went wrong, a lawsuit followed, got compensated but not enough to have the work done. So, I’m at it again stripping everything off and making some small changes while doing so
I have painted a couple of boats with two part polyurethane paint systems including the topsides of my Nonsuch 33.
If you have not yet repainted your boat, you might consider the following excerpt from the Alexseal Application Guide.
Procedure For Application of ALEXSEAL® Premium 501 Topcoat By Spray After applying ALEXSEAL® Finish Primer 442 according to the procedure in the “Technical Data Sheets” starting on page 62: 1. Clean area to be painted and sand with 320 - 400 grit to a uniform finish. Remove sanding residue and wipe the surface clean using the “Two Rag Cleaning Method” starting on page 31. It is recommended that the ALEXSEAL® Topcoat be applied within 4 days (2 days if outside) after sanding to ensure adhesion. 2. Apply 2 - 3 coats to a wet film thickness (WFT) of 2 - 3 mils (50 - 75 microns) per
From your photos of today, it looks like the primer you applied last year is still on the boat. Is that primer fully compatible with your selected topcoat? Do you plan to paint some test areas to prove adhesion before painting the entire boat?
I used Alexseal on my 26 and 9 years later she looks like the day it was done. I found the Alexsseal technical support was outstanding. Called me back on a Sunday afternoon to discuss options. I’d not apply a drop of paint with out talking to them. They provided a good deal of information that is in NOT in the product spec sheet.
Wow. Talk about quality work, Mark. I do hope that you came out at least a little bit ahead on your painting debacle. are you going to do the entire repaint yourself ??
