Racor Fuel Filter Housing
Westerbeke did say 30m… surprised me too. It was the service manager for Westerbeke at the time. who informed me. The lift pump I have now is a Facet and it has a plastic mesh that is cleanable vs the paper one in the original. No Both on engine filters are Mitsubishi parts not Westerbeke.
Apparenly the new mesh ones are 74m
https://pbase.com/mainecruising/facet_fuel_pump_filter
Hi folks,
I’m troubleshooting a diesel leak by the aluminum retainer ring of the engine’s first filter. Engine is a W13.
I replaced the filter, the small and large o rings.
Because of the rough texture of the aluminum ring, i figured it should be tightened by hand. Result: diesel leak.
Second attempt, tightened it with pliers.
Third attempt, added a second, slightly thicker o ring, in addition to the supplied o ring (so two large o rings in total). Result: better, much better, but still leaking a bit of diesel!
I’m now considering removing the second “larger” o ring, and adding a flat o ring.
Thought i would bounce this off on the Nonsuch Collective before continuing on my little Frankenstein journey!
Thank you
Val
NS26C #75
Ottawa, ON
NSC
First off, Val, I believe the filter in question is more appropriately called the secondary filter. The first one being the one closest to the tank. I’m not sure if that #13 is an “O” ring or a flat seal. I can’t find my parts manual.
![image.jpg|1057x1446](upload://tTknVrlp82CraU90dNXiBGp1fLm.jpeg)
I take that back, Val, the manual calls it the primary fuel filter.
Here’s the kit I used. It’s an actual Westerbeke/OEM product. The rings, in both cases, are definitely round, not flat, o rings.
Roger that, Val. In that case, I have no suggestions except to carefully look at that cup and cap.
![image.jpg|3024x4032](upload://uHqhn0V7GIQL1aE9fHKPvtJZoeG.jpeg)
There was always a problem reusing the aluminum ring to tighten
Put new ring on and shud be no problem
If I recall a new ring came with replacement filter
Cedric Single Malt
26C # 207
Chester Nova Scotia
Start over.
Just install the correct large O ring13, can 17, and ring16, with no filter. Use fingers only. You will feel when the ring gets to the point where the O ring is starting to compress. Remember where this is.
Take it off and put the new filter in with the small O ring and reassemble with the one 13 O ring. Screw the knurled ring on by hand. Note if it doesn’t go smoothly on all the way like the fist step, it will leak, and what happened is the filter/small O ring isn’t lined up correctly inside.
It’s hard to see but that new filter/small O ring fits in/on a thing inside. It must be on there correctly.
My kit never had a new knurled aluminum ring. I think its original. It goes on with fingers nicely but I’m sure it could be cross threaded easily.
Finger tighten.
No leak.
If you use a bigger O ring or two O rings the fuel will just go around the filter and the filter won’t be doing its job.
26C #28 W13
On Wednesday, 11 May 2022 at 08:49:36 UTC-4 Val NS26C #75, Ottawa, ON wrote:
Clarification: both 13 and 14 slip right into the little groove. Perhaps I should just try it again and tighten it by hand, not too tight. I definitely have a tendency to over tighten things… more is better, right :wink:
The knurled aluminum ring did not come with the kit. It is original to the engine.
Here i go again. Wish me luck :four_leaf_clover:
Val
Good idea, Tom. BTW, where are you located??
It’s in my initial msg from earlier today, Joe :wink:
We don’t require it, but it helps when it’s in the signature.
