Removing prop shaft/ shaft log Universal M 35 on 1990 Ultra 30
If shaft is removed thru the cabin, does that mean that a transmission seal must also be replaced? What special cautions are required? Here is my expected process:
1.) Loosen clamps on rubber shaft tube
2.) Loosen packing nuts on shaft log
3.) Remove two piece shaft clamp between shaft log and trans
4.) Remove prop and shaft zinc
5.) Mark shaft flange and transmission flange to assure realignment on re-install
6.)Unbolt shaft flange from transmission
Not sure what I have missed. What are the pitfalls to be aware of?
Harry Bloom
#512 Nonsuch 30U
Tell us where the boat is in your posts and you might find another boat like yours nearby that could help.
Boat # 512
Typhoon Harry
Crescent Sail Club
Grosse Pointe Farms, MI
That sounds about right Harry. If the top of the shaft has been scored you may have difficulty getting the top flange off, if not you’re in luck. If the flange is stuck the shaft will still pull through. You might need a press to get the flange off. I did and the shaft was toast afterwards. Had to buy a new shaft and flange. Bought a split flange which is so much better than the stock flange. Have the shaft dealer face the flange to the shaft for perfect balance. BTW there’s no seal to worry about.
Ron
Ron & Diane Schryver
“Alpha Waves” 1987 NS30U #393
Georgian Bay Midland ON
Shaft removal was easy. Of course the cutlass bearing took a bigger hammer. Fortunately, I had a crew member available to help.
Harry
Another way to remove and install the cutlass bearing is with a puller/pusher. You can buy one or make your own. Basically made up of some steel plate, pipe and long bolts. The pipe pushes against the bearing and the bolts pull the pates together pressing the pipe against the bearing. Can be done with the shaft in place if one of the plates is in two parts and the pipe is in cut in half so it can wrap around the shaft.
Rob Powers
Respite 26c #50
sidney BC
Harry
Shaft removal proved easy. Cutlass bearing required a bigger hammer. Long time crew member did the honors while I supervised.
Harry Bloom
#512 N30 Typhoon Harry
