My elderly Westerbeke W52 is on its last legs. Have any owners replaced theirs, and what have you installed? I’m considering Yanmar because it is so popular and therefore easy to service, and parts are less expensive than others.
I’m moored in the Merrimack River, Newburyport, MA. Though I’ve sailed in and out of the Merrimack for nearly 40 years, I’ve come to respect the river and its power. More people have died in the mouth of the Merrimack over the past half century than any other tidal river in North America.
We have regular outgoing tidal current in the 4-5 knot range, with a tricky entry at the tide change. I therefore need dead reliable propulsion.
Some folks I know have gone the Beta route and regretted it, as the quality of parts is inconsistent. My local yard is first rate, and they refuse to install Beta engines. Of course, they’re a Yanmar dealers, so….
Barry: Being a retired mechanic, having delivered boats for a bunch of years and personally knowing every yard owner in my neck of the woods, they’ve never said anything negative about Beta. at least one of them is a Yanmar dealer. In the past, Yanmar has been bad at parts replacement. They may have gotten their act together, though.
You might want to read a 2021 buyers guide to marine diesels from Yachting Monthly. Two things I thought of when reading your original post:
As reliable as Yanmars are, their use of the common rail system does introduce electronics and complexity. Since I motor regularly but not for very long, their efficiency vs. complexity as well as the fact that I do almost all my own maintenance means they would not be my first choice. That doesn’t mean it shouldn’t be yours.
I’d avoid any manufacturer still using glow plugs. Or at least one that requires them for starting under normal temperatures (the Yanmar on my previous boat did start rather rough below about 50 degrees. But I never thought is wasn’t going to start.)
Dan Weinstein
Look Farther, 30C #205
East Greenwich RI
Given the number of satisfied customers who have gone to Beta’s the shops that refuse to install them have agendas and should be avoided. Bd mouthing the competition never wears well.
Definitely with currents of that order going up in HP might be a consideration. I would ask the question to Beta.
As far as parts, Beta engine parts can be had at any Kuboto Tractor dealer of which there are 1000’s.
Yanmar like Volvo are proprietary and although Yanmar makes John Deere engines, there is little chance you can cross reference parts and the minute you say Yanmar to the JD dealer he’ll refuse the sale.
So parts availability goes to Beta .
There are plenty of Yanmar engines in the Nonsuch fleet for a reason, they are good engines. If you have one staying with them makes sense. Like Joe mentioned the common rail aspect is of concern, it really does not add anything to the application and adds complexity. It does make sense in the agi tractor market and that is the reason.
Beta has built a business model around replacement engines and have a very slick service where you pre measure your current engine mounts and they deliver a engine ready to match .Saves time, money and frustration. So unless you have a Yanmar in place this is something to consider. They have done a lot of Westerbeke swaps.
Long story short… if it was my decision I’d chose Beta.. Interestingly enough the local Beta dealer is the go to guy for Yanmar and Volvo repairs , not there local respective dealers.
I replaced my old Volvo with a Beta 25. I had sold and services many Kubota diesels in hard working construction equipment so I knew they were tough, reliable and well supported. I liked the thought Beta had put into the marination of the engine with everything easy to get at.
When the time came to make the switch the mechanic wasn’t available so (at 78) I did it myself with a little help from my daughter. As Thor mentioned, the engine fitted the old engine bed and Beta’s directions were easy to follow and the dealer was helpful (you would think they were expecting me to put it in). Installing it myself probably cut the cost in half.
The hp requirements are hard to pin down. I have read two hp per ton and 4 hp per ton. Some say long tons (2200) and some say tons (2000 lbs). An article in Practical Boat Owner from several years ago said 2 hp per ton used to be the standard but 4 is the new standard. The 36 is listed at 17,000 lbs but I suspect in cruising mode the 36 would come in at over 20,000 lbs or 10 tons. This suggests 40 hp is a reasonable number. The W52 was rated at 45 hp continuous running at 3000 rpm, 52 for one hour at 3000.
In terms of which engine you will want to consider the layout and how easy daily engine checks and servicing will be. Westerbeke is not making any engines in this powering range that can be shipped in the U.S. Volvo parts prices are extremely high so you probably want to stay away from them. That pretty much leaves Yanmar or a marinized version of a Kubota engine, Beta ,Nanni or Sole. Beta would be the best because of the Kabota blocks because they have the biggest presence in North America. Parts availability for the Yanmars on the West Coast has been an issue for a few years. I believe it is better on the east coast.
From what I have seen the 36 came with a V drive transmission. Is a. Drive available for the Yanmar you are considering? Exhaust mixing elbows for Yanmars have a short life expectancy and OEM prices are predatory. Custom made stainless steel elbows are less.
I know that Phil LeVine was very unhappy with the Westerbeke factory’s handling when he repowered his 36 with a new one from them. He was promised drop-in compatibility and found nowhere near that.
I don’t know if he’ll want to post more on that or not, but I feel safe saying it’s another data point for any replacement other than Westerbeke.
Another point that may be of interest in the Yanmar vs Beta discussion is that when I was looking for new engines for our small ferry fleet years ago Yanmar (and Volvo) were unwilling to warrantee their engines for the service hours we would be giving them. Beta and Vetus (Mitsubishi) would. To me that says something about the suppliers confidence in their product.
