I found my post from 2022 and repeat it here for all to see. Worst part was getting the four screws out as it took two weeks of soaking and banging plus drilling.
Joe, by “turning wheel below the pedestal” I take it that you are referencing the idler sheaves mounted on the underside of the cockpit sole, correct?
Ken Dakin
NS 33 # 7
Sashay
Kingston ON
I believe so. You need to have some slack.
Fortunately, the 4 bolts were not a problem. They will go back with anti-seize for the next time. We (my son) will descend into the “cave” and measure the cables this weekend.The Edson instructions say that you can sneak the plastic retainer past the shaft, but then go on to recommend moving the chain forward for room. We will see! Detaching the idler block sounds interesting, as it does not change the cable settings for the steering. Fairly sure the problem is the cable, as it kinks a bit at the forward end when it moves, but I will change the lever bushing while we have it apart. Thanks for the help.
Persuasion NS 26U
Essex, CT
I replaced both my cables earlier this year, admittedly with my mechanic’s help to install new ones. I didn’t have any issues pulling off the binnacle bits, no seized bolts. I followed instructions in Edson manual (see attached), and my added comments are…
Replacing the shifter cable saved banging my knuckles every time I put the boat into forward. And makes maneuvering in a marina a little less stressful, highly recommended. I choose to do the throttle at the same time, although the old one seemed okay. The manufactured date on my old cables was 1985, so I think they were due for replacement.
Hope that helps.
’87 NS30U #369 - Breezin’
Vancouver, BC
Edson Engine Control Cable Installation Instructions.pdf (71.5 KB)
Edson quadrant.pdf (134 KB)
