Need to replace my shaft seal on Nonsuch 30U. I know the shaft is 1". Plan on buying a PYI shaft seal but need to know the diameter of the shaft log (the tube that passes through the hull). Thanks in advance for any help.
Lloyd McDonald Thistle #390. 30U
If the boat is not in the water, remove the bellows and measure the shaft log.
You might find that buying the rubber kit from a place like Defender is less costly than direct from PYI.
Ward Woodruff N33 #8 Margery Niantic Bay, CT
I did mine two years ago. It’s 1 3/4” for the shaft tube.
Paul M NS30U #211, Sandpiper Cowichan Bay B. C.
