Does anyone know the part number of PSS shaft seal for a 30U with a 1" shaft or the shaft log inside diameter? I need to buy a PSS service kit, and thought I’d try to figure out the correct one before lifting the boat. The part depends on the shaft log diameter, but it’s difficult to tell with boat in the water.
'87 NS30U #369 Breezin
Vancouver BC
Hi Don.
The replacement bellows kit number is : 07-100-134R
That is for a 1" shaft diameter with 1 3/4 to 1 7/8 stern tube.
Mine is being installed today! It was well overdue.
Brian Taylor, Wireless, 1987 NS 30U #400 Tauranga, New Zealand
Thanks Brian, hope your kit install goes well.
Hey Don. The replacement went well. Two hours with a mechanic and myself the gofer. The replacement kit I mentioned IS the right size.
Great… hope mine goes as well. And yes, I’ve received info from others that concurs with your info and part number.
