Spare halyard and flag lines on a 26
I replaced the halyard on our 26 last spring; have the old halyard still with the shackle on and wondering what to do with it.
Q: With the spare block bolted to the outside port side at the top of the mast, is it worth putting the old halyard on it? New halyard has a well spliced eye (not by me, by a professional rigger) and I don’t expect it to break nor do I expect to lose the tail up the mast.
Currently, that block is used for a flag line, a small 4mm line which I tie off on the pulpit. I’m thinking about flag lines on the boom where the forward reefing/topping lift blocks are, and not worrying about the flag line to the top of the mast.
Any “current best practices” from anyone for this relative newbie?
PS - Paul Miller - the old halyard shackle has a roll pin holding the middle bar in place, not screwed like yours is. FYI - always learning something.
John Stewart NS26C 046 Bath ON.
John -
I have a thin flag line that goes from the very front end of my boom down to a 5" loop of shock cord (bungee cord) that is tied right through the middle of my bow cleat, forward of my mast. That is where I fly my club burgee from. The line is mildly taut and the shock cord keeps it taut as the boom turns from side to side. I have a permanent dock line tied to this cleat so the whole thing never gets undone or messed up.
Question - I know that this “spare block” at the top of mast has been covered a fair bit in this group but just how beefy and well-attached is the block ?? I ask because there has been discussion about a spare halyard being used as a safety for a bosun chair lift of “someone”.
Furthermore, NONE of us ever expect to lose our main halyard up the mast. Ha Ha Ha !!!
Flag line.pdf (120 KB)
John,
Ernie’s approach strikes me as a pretty nice way to do a flag halyard.
As for the block on the top port side of the mast, you might consider a compromise. Leave the current flag halyard light line in place and think of it as a messenger line for pulling up the old halyard line if/when you need it. A second halyard has additional uses over and above going up the mast. It’s handy to have two if you’re raising/lowering the wishbone, as well as if your topping lift or its stopper line fails or is being replaced. None of this happens often enough to merit leaving a big line in place permanently. But keeping the old halyard in storage just in case and a light line in place as a messenger makes life easy if you ever need it.
That is a fine idea, Bob. A messenger line that’s always there.
Smart.
I have the cheek block at the top. I run a 1/4 line to it and can use it to run a beefier line when I need a safety line. There are modern mast climbing rig that preclude the need for a second line.
However I have a 1/4 line that I run to a block secured to the side of the boom casting with a hose clamp, I have some rescue tap under the clamp. I use this line for flags and the radar reflector.
Would you have a photo of that setup? I cannot picture just where you have that block on the boom. I cannot reach the front casting and the aft casting seems as though the line would interfere with the sail.
Tim in STL
White O’morn NS26U #216
Harbor Point Yacht Club
West Alton, MO
Just a “thanks” for the very welcome replies to my query; interesting stuff to ponder - at least nobody’s suggested I rig a blooper like the manual says. (smile)
JohnS, NS26C 046
John,
I would suggest you use that line to rig a blooper on a mild day and try to turn that cat into a bird. Just so you could say you did.
Boat-less in New England
