I need to remove the existing thru-hull for the Datamarine/DMI depth-sounder and replace with a new one that will accept the new/current transponder. DMI indicates that the hole is the same for the new thru-hull. Does anyone know how the thru-hull was bedded/sealed into the hull? 3M 5200? Has anyone done the removal and what were the problems encountered? Thanks for any input!
Joe Wauters NS 36 Deep Powder
The way I removed mine was to stand on it and push! My new Raymarine transducer fit the same hole.
Sea Harbour Yacht Club
Oriental, NC
Try heating the seal with a hair dryer.
(Assuming that you are not in the water)
Ed Collis
ORION VII
You could just leave the old transducer in place, and cut a new hole.
Ed Collis
ORION VII
in my west marine 2009 page 218, bottom left corner is a product “antibond 215” . I have successfully used it to soften 15 year old 3M2500 for easy removal. This will save you hours to remove the depth sounder.
Lorie (& Angie) Simone
REVELATION NS30U #260
Kingston, ON
East - Lake Ontario
613 634 7457: Fax 613 634 2674
You mmay want to consider filling the hole and mountain the new depth sounder inside the hull and shoot through the solid fiberglass . If done properly the loss of resolution is minimal and possible leakage eliminated.
Fritz Reilly
“Grappa”
NS 36 31
Faced with a similar situation when I recently replaced my Datamarine
with a Raymarine depth sounder, while in the HOH, I used the new depth
sounder in a bed of silicone alongside the existing DM. It works
perfectly. I have done this before and it works as long as you use an
area of the hull where it is solid fibreglass.
ron<<
S/V Serenity
Nonsuch U 479
Gulfport, FL.
