Congrats, James. It’s a great boat (but it’s not a trailer-sailor). With the boat weighing 8500 lbs. (bone dry - no extra gear inside), I’ll bet that the mast and boom weigh around 450 lbs., give or take. Then, to be safe, as a contingency, add 1000 lbs.
Don’t be fooled by the “two-piece mast”. You do NOT want to take the mast apart and re-assemble it unless you must, in order to repair or rebuild it. Every mast joint is a bit different and it may be shimmed, etc. The height of the mast from the water is 49 feet so you’ll be trailoring a stick of 49’ + (and it’s as heavy as a dead cow … sort of).
Any boat that can be legally trailered can be … uh … trailered. I suppose. And, the Cape Hatteras lighthouse was actually moved. That doesn’t mean that it was fun. Or quick n’ dirty. Obviously, you are looking at a lift in and out and a mast crane in and out, per move. And lots (and lots and lots) of prep time. I also believe that every time you load and unload a big boat like this on to a trailer, you run the risk of something going wrong. I also wonder how accomodating your insurer would be with the idea of the boat being transported by you as opposed to a pro mover.
I wouldn’t even dream of doing this unless I had utmost confidence in the experience of the trailer fabricator and had the same type of tow vehicle that is commonly used for a fair-sized fifth-wheel trailer. Everything very heavy-duty. Lots of fuel consumption.
I am basing my opinion on almost no real world knowledge of highway boat transport but more than a few hunches, some anecdotal “evidence” and experience with a smaller (22’) Nonsuch that I wouldn’t trailer, ever.
I am glad you’ll have the boat. It’s the best and you will love it (until you try to schlep it around as if it were a West Wight Potter). I look forward to the sage advice and comments from those more experienced than myself.
Finally, me being a former Montrealer and you being an Ottawa native, is this, by any chance, part of a scheme to bring the boat down south and escape the winter (a noble thought and highly understandable) ?? If so, sincerely, buy another boat (maybe smaller and cheaper) and keep it down south. Hassle-free and a practice that is common with many Canadian and northern American sailors.
Good luck.
