Why is there "always" water in the bilge for Nonsuchs??
In the case of Nonsuch Luck water was entering the bilge around the keel bolts. In the end, I had the keel dropped and re-bedded which has stopped the leaks. Rainwater still gets in via the mast and a small amount eventually makes its way in the bilge, but it doesn’t amount to very much.
Here’s a link to the photos I took of the whole process keel re-bedding.
Bob Illingworth
Bob Illingworth
