Wire Topping Lift Length (from 12/2023 & 01/2025)
Wire Topping lift Length
Steve Foose's profile photo
Steve Foose
Dec 12, 2023, 7:52:37 AM
I can’t find the length for the wire topping lift for a c30. (#428 c30). Can some one please share that. I know it is. 7 19 wire. 2 eyes. Have the penant lenght too. Need to make a new topping lift. And don’t have the old one.
Steve foose.
Jules Verne. #428. C30
Boat in Grew turtel cay. Bahamas
Pittsfield Masj
Joe Valinoti's profile photo
Dec 12, 2023, 8:42:19 AM
Have you tried the owner’s manual, Steve??
Ernie Abugov P/O NS22 o/b #56 "Moustaches"'s profile photo
Ernie Abugov P/O NS22 o/b #56 “Moustaches”
Dec 12, 2023, 9:39:22 AM
Hi Joe -
I just checked out the owner’s manual for the C 30 and, while I found mention of the wire T/L, I could not find any indication of the LENGTH of the wire.
Mike Quill's profile photo
Mike Quill
Dec 12, 2023, 12:00:40 PM
Hi Steve
The wire length is 45 feet on a Nonsuch 30 . It is recommended to swage on a 3/16 marine eye coupled with a 3/8 toggle at the top end and a nico press eye at the bottom using 2 sleeves.
Mike Quill
Brian M. Godfrey's profile photo
Brian M. Godfrey
Dec 12, 2023, 12:25:07 PM
I’m curious whether Steve has considered replacing the stainless wire with Dyneema. And if so, why have you decided against it? I’m not advocating anything, just trying to learn. I recently replaced my boom hangers with Dyneema and the rigger strongly encouraged me to replace the topping lift soon and with Dyneema, too.
–Brian M. Godfrey
br…@wildbirdshop.com
Mark Powers La Reina 26C Vancouver, B.C.'s profile photo
Dec 12, 2023, 1:59:13 PM
On the question of Dyneema, one of the members of our group said they had Dyneema for the standing part of the topping lift when they bought their boat. They found that when they were at anchor and the wind reached a certain velocity the Dyneema would start to vibrate and set up a loud humming noise which made sleep rather difficult.
There is probably not enough benefits with Dyneema to out weigh the downsides. Stainless wire will last much longer than Dyneema. The coated stainless is likely no harder on the sail than Dyneema. Dyneema is stronger so you could go with a smaller dia however it is subject to degradation due to UV. The UV attacks the outer layer of Dyneema so the smaller the dia the higher the percentage of the line that is compromised. This means you can’t go down much, if at all in size unless you plan to change the line very frequently. If the Dyneema and stainless are the same size there is no aerodynamic advantage to Dyneema. The difference is weight is probably too small to notice. Dyneema is easier for most people to work with. Most of us don’t have the necessary tools to work with stainless wire so must use a rigger while with a little effort we can all learn to put a locking Brummel eye splice in Dyneema. If you use Dyneema you must do regular inspection of the line at the top of the mast since it will be at risk of chafing.
The same pros and cons probably apply to the Dyneema vs coat stainless forex boom hangers.
Using Dyneema instead of polyester for the running tackle on the topping lift may be worth while. The Dyneema is very slippery and will slide along the boom with less friction. You can use a smaller dia, which will also reduce friction. Bare Dyneema does not work well in rope clutches so you might want to use covered Dyneema or even polyester line for the portion of the tackle running along the cabin top back to the cockpit.
As for length. My experience is that a little shorter on the standing part of the topping lift is better than a little longer. When Ed Botterell made a sail he would place the reef crinkles higher up on the leech of the sail to keep the boom higher in rough weather. I found that with the regular length of the standing part of the topping lift the two blocks on the tackle would hit before the boom was lifted high enough to put in the reef. I had to shorten the standing portion by 3 feet to solve the issue. I had 4:1 purchase on the tackle so when I shortened the standing portion by 3 feet I had to get a tackle line that was 12 feet longer.
Those are my thoughts. I could be wrong.
Dec 12, 2023, 3:01:30 PM
Long ago (2012), in a far-off galaxy, just after I bought my NS 22, I had Mike Quill redo the mast joint. When the mast came back, it had been COMPLETELY (and beautifully) redone with all kinds of stuff thrown in (for really cheap or for free). One thing he did, was to replace the original boom hangers and standing topping lift with decidedly thicker cable than the originals. I don’t remember the size (thickness) of the new cable but it was visibly “over spec”.
In 11 years ownership, I never once worried about any of those lengths of covered steel cable letting go (for any reason). I mention this because, perhaps, Mike could let us know what gauge steel cable he truly thinks would be best for this application on an NS30C.
I think that Dyneema would certainly “do” for this purpose but steel cable would be far more appropriate - I’d be more confident knowing that th boom was held up by steel cable. I think Mark is right on, though, by suggesting a slightly shorter standing part of the T/L. A good idea IMHO.
Steve Foose
Dec 12, 2023, 3:15:53 PM
Yes. Not in the one I have. Just wire spec.
Cedric Guthrie's profile photo
Cedric Guthrie
Dec 12, 2023, 4:36:28 PM
Ernie
Covered wire such as was used for lifelines and topping lifts is no longer readily available/ manufactured due to the impossibility to see any detioration (rust etc) and thus possiblity of failure under strain Certainlyy use for lifelines is not acceptable
If one was to use wire as a topping lift then one would very quickly have a dirty look in sail - hence the use of dymeena or however you spell that very suitable “rope “ to use as a topping lift
Safe Sailings
Cedric
Single Malt 26C #207
Chester Nova Scotia
Dec 12, 2023, 5:41:01 PM
Hi Cedric -
I do not disagree with you. One cannot check the condition of the cable if it is covered. That said, it certainly is still sold. Here’s a link to Defender:
https://defender.com/en_us/suncor-white-coated-7x7-stainless-steel-lifeline-wire
Or West Marine:
https://www.westmarine.com/suncor-3-16inch-lifeline-wire-rope-7-x-7-5929658.html
Dec 12, 2023, 5:43:07 PM
I forgot to mention that my topping lift was PVC covered SS wire. It was on the boat for 11 years (and still is) and left no mark on anything. Granted, the boat is a fresh-water vessel.
Donald Mc Nees Jr's profile photo
Donald Mc Nees Jr
Dec 12, 2023, 8:00:19 PM
I did something with my topping lift last March that at the time seemed to raise a little controversy. I removed it. I bought “Cheers” late Nov. 2022 and hauled it out early March 23. Everything went as well as could be and in removing the mast for inspection I found it to be in good shape with no problems, but time had not been good to the topping lift. Cable, blocks, lines and fittings all needed replacement,
I also discovered the mast had a double sheave top fitting in good shape. I fitted a new internal halyard. Nice to have a spare. That’s when the idea of using that halyard as the topping lift struck. A line run to the top seemed wasted if just cleated off and not working. I did this and eliminated the cable, the block tackle, the line that runs along the boom and back to the cockpit and the safety cable. A lot of stuff swinging with the boom on every tack or jibe.
We have sailed many miles in the Salish Sea with this set up and have had no problems. It can be led to the port side cabin top winch for sail trim and has its own stopper clutch. I can lower the boom with it. I can sew a mouse to it and run the whole halyard/topping lift for inspection with the boom down and resting.
No down side so far, but I will pull the mast again in May 2024 when I haul out for bottom paint etc.and inspect. A little controversial but I won’t be going back and if you have a double sheave mast top you might consider the option.
Don Mc
NS 22 #16 “CHEERS”
Puget Sound
Steve Foose
Dec 12, 2023, 8:28:41 PM
Thank you all for your thoughts - recommendations - and sharing your personal Experiences
The Question is simple How long is it - Eye to Eye or to the pennant.
How I end up doing it ( replacing it - is a separate issue )
Can anyone give me that measurement - Ill gladly share what I do.
Thank You
Steve Foose
Jules Verne -c30 #428
Being Reborn In the Abacos Bahama (A Dorian Hurricane survivor - 200 mph winds - 2 days )
– Replaced the Engine ( used)
Sleeved the Mast (Yes Lower section 8 Ft - It can be done - Did it )
Re doing all the running rigining Now Need the Topping lift Length )-
Will be in the water Motoring and Sailing by End of January )
Dec 12, 2023, 9:00:13 PM
45 feet per Mike Quill in his noon response to this thread.
N33 #8 Margery
Niantic Bay, CT
Steve Foose
Dec 12, 2023, 9:03:06 PM
Ward Woodruff's profile photo
Dec 13, 2023, 12:27:43 AM
I did that because Mike’s reply had apparently been overlooked by the guy asking the original question. Trying to be helpful.
N33 #8 Margery
Niantic Bay, CT
Spending 18th day in Phuket Thailand hospital attending to my wife and bored.
On Dec 13, 2023, at 11:33 AM, Don Crossley <doncr…@gmail.com> wrote:
Sfoose's profile photo
Sfoose
Dec 13, 2023, 6:53:27 AM
to INA-Nonsuch-Discussion-Group@googlegroups.com
I didn’t see it either. So the Repeat was not a repeat of info to me.
Again. Thank you.
Steve. Jules Verne
Dec 13, 2023, 8:29:34 AM
I saw Mike’s response. I changed mine from wire to Dyneema about 10 years ago and now worry that it may be deteriorating. If it does, I’ll go back to wire rope and worry less. I’ve found that when it does start to go bad stains show up on the cover and are easy to see.
Greg Silver's profile photo
Dec 13, 2023, 10:20:03 AM
Hi Steve,
Wondering if you and your Nonsuch are in Green Turtle Cay now? I hope to be there soon, storm stayed in Bimini at the moment (not with my Nonsuch, sailing with a friend on an old school sloop). I would really like to see the repair to your mast. Haven’t been to Abacos since pre Dorian and hoping to find people and things in better shape…
Misty Cat 26C #121
St. Peter’s, Cape Breton
Nova Scotia
Brian M. Godfrey
Dec 13, 2023, 1:48:26 PM
The Dyneema will deteriorate, as will the stainless. During my boat shopping year I learned that some insurance companies require stainless steel standing rigging to be replaced every 15 to 20 years, though it’s just hearsay, really. That’s why I asked the rigger to scale up my Dyneema boom hangers from the 1/4" that he was recommending (same as the wire diameter) to 5/16". It just gives me more margin. Since it is good for a whole lot more weight that the couple of hundred pounds that each boom hanger will take, I feel pretty confident that it will last me for a very long time even with significant degradation.
The 1/4" wire, assuming it was 316 stainless, has a breaking strength of 4739 pounds, according to a chart I found online. 8mm (5/16") Dyneema has a breaking strength of 9 tons with eye splices or 18,000 pounds. So it can degrade an awful lot before it gets down to the strength of brand new stainless.
I’m curious about the stains on the wire cover. The rigger looked at the old wire boom hangers and said they needed replacement. Being as it had that white covering on it, I didn’t know how he could tell. It did have rusty splotches all over it, but I assumed they had just collected from some external source. Can the rust spots actually seep through the plastic or something? Otherwise, how do the stains on the outside tell you anything about what’s going on inside? (My topping lift does have some minor rust stains, so it is something I am starting to wonder more about…)
Finally, one last note for Steve: you may already know about this, but if not I have found it to be important from personal experience: The topping lift wire/Dyneema line goes most of the way towards the end of the boom and then there is running rigging the rest of the way to the boom end to allow for adjusting the overall topping action. I’m sure you already know that part. But there is also an additional piece of wire/Dyneema which bypasses that running rigging and acts as a safety line. So if someone accidentally releases the topping lift line from the winch on the cabintop the boom will not just freefall onto someone’s head. Don’t forget that safety line.
–Brian M. Godfrey
BRIAN CAYER's profile photo
BRIAN CAYER
Dec 13, 2023, 4:02:12 PM
Concerning the missing topping lift length from Mike Quill, I have found that if two or more people are in the process of responding simultaneously or are responding to the originator alone the thread goes forward with some data missing. If not sure I always open the website for complete information.
Brian Cayer
Deep River, CT
Bob Neches (Me Gusta, Nonsuch 26U #233)'s profile photo
Dec 13, 2023, 4:11:19 PM
Seeing as how the original poster has gotten his answer and the discussion has moved on, I can’t resist throwing in my $0.02.
Re dyneema vs. stainless steel, as my father used to say, it’s six points for one vs. half a dozen points for the other. You can make either one work just fine. It’s a matter of whether you prefer the ability to do it yourself with dyneema or are more comfortable paying a rigger. And maybe whether UV deterioration scares you more or corrosion scares you more. Me, I like dyneema, and use it wherever I can.
To the guy who did his N22 to get rid of his topping lift and rely on a second halyard: I inherited a similar arrangement when I bought my current N26. I am not happy about it, and would not recommend it – particularly on the larger boats.
As the wishbone gets heavier, you don’t have the purchase that you have with a multi-part block arrangement at the end of the topping lift. With a fixed topping lift kept appropriately short, you can have both the multi-part block for adjustments and a keeper line to protect you from the boom dropping. I ended up adding that multi-part block at the end of the second halyard.
When something that should be standing rigging is set up using running rigging, which is what we’re both doing with the halyard, you then have to set up something to keep it fixed in position (e.g., run it through a jammer, tie it to a cleat, …). Then you have to worry not just about that set-up failing, but also someone making a mistake with it. That means tying stop knots, putting up “Don’t touch this” signs, somehow securing the lever on your sheetstopper, … or whatever. Then you have to worry about being able to undo when needed whatever preventative measures you just put in place.
Last, but not least, the second halyard is a back-up both for main halyard failure and in case you need to go up the mast. If it’s in use as a topping lift, you lose that.
If, like me, you’ve inherited the situation, it’s not so bad that you can’t live with it. But I don’t think it’s a good idea to switch from topping lift to second halyard on anything bigger than a N22.
Daniel Weinstein's profile photo
Daniel Weinstein
I thought I’d add a couple items that I didn’t see discussed about Dyneema, especially for this use case:
– The working load of Dyneema, and all ropes that terminate in a loop, need a minimum bend radius to support the load. This is because the strands on the ID bear a different load than the OD. Samson recommends 3x the rope diameter for pin terminations. Active sheaves, 8x. People often overlook this, it would need to be factored in for the topping lift terminations, where a wire swage does not have to contend with bend radius (if not swaged, there is a similar requirement though).
– There’s a lot of different Dyneema. I use Samson’s Amsteel Blue for my mooring bridle, because it has a UV coating. The bend radius where the loops connect to the 3-strand pennant isn’t an issue, but between the 1" radius at the bow cleats, and the eventual UV degradation of the outer layers, I calculate that the 30,000lb minimum strength rating has now been reduced to about 10,000lb after a couple years, but I’m still ahead of the game compared the 3/4" polyester setup I had.
That said, when I moved my topping lift adjustment from the aft end of the boom to run in the “lazy jack loops” and back to the cockpit, I used 58’ of 3/16" New England Ropes HTS 75 Dyneema, in-line spliced to 20’ of conventional double-braid for the cockpit winching. When time comes to replace my topping lift wire, I’ll likely use some form of Dyneema to reduce weight and to be able to do the work myself.
Dan Weinstein
Look Farther, 30C #205
East Greenwich, RI
Captain Greg
Dec 10, 2024, 1:15:34 AM
This is an older thread, didn’t want to start a new one, hoping this makes research easier for others going forward.
I am rejuvenating my 1983 Nonsuch and generally making things simpler, for my 8th decade of life, which I think will primarily be day sailing and shorter overnight cruises of a few days, on Bras d’Or Lake and coastal Nova Scotia. I am eliminating some tired systems I won’t need (water and cabin heating, for example), and renewing the ones I will need. Overall goal is to simplify maintenance while keeping the boat suitable for my more limited sailing plans.
Among the new upgrades are the topping lift, which in my case has been a fixed standing length, PVC coated wire, since new in 1983. That coated wire was replaced by Mike Quill just a year before I laid Misty Cat up in fall 2019. Planning to relaunch soon. I want to have an adjustable topping lift, and am looking to shorten the existing fixed wire, connect it to a pennant and run that to the cockpit. I am thinking of putting the load-reducing blocks in the drop from the wishbone to the deck, rather than above the wishbone, similar to how our chokers are rigged. This would enable me to use a Dyneema or similar slippery non-stretch line (from end of standing wire topping lift from mast) along the wishbone and part way down the mast, to the load-reducint block and tackle. Through that block and tackle I would use a covered line suitable to go to deck and then a deck mounted rope clutch into the cockpit.This location seems to make it easier to service, install and remove these blocks at fall and spring hauls and launches when I step/unstep the mast.
Wondering:
  • if anyone has any comments about moving the tackle from above boom to adjacent the mast, and from other 26’rs out there?
  • how long is your wire topping lift to the adjustable block and tackle? As Mark Powers pointed out below, it needs to be short enough to accommodate more extreme adjustments for reefing - looks like he shortened by 3’ from aft end of boom. I may have read this wrong…This is the magic number I am looking for so I can calculate the length to shorten standing wire, and then calculate for pennants to reducing blocks, and then to cockpit.
Thanks and cheers,
Misty Cat 26C #121
Nova Scotia
Rob Cohen "Soave" NS33 Westport, CT's profile photo
Rob Cohen “Soave” NS33 Westport, CT
Dec 10, 2024, 8:52:58 AM
Hi Greg,
It is appealing to remove weight and complexity from the end of the wishbone and bring it inboard and centered.
I am not familiar with the specific dimensions on the NS26, it looks like Soave ( NS33 ) may have had a block and tackle mounted on her mast at some time in her past. I see dings and scratches possibly caused by the floating end moving up and down the mast. The dings were probably from slapping, not sure about the scratches. It’s kinda ugly and looks more vulnerable to the effects of weathering.
When rigging for this change, be sure the angles are such that the floating end of your block and tackle cannot engage with your mast. Seems doable, but for some reason this detail may have been overlooked on Soave at some point in her past.
When I purchased Soave in 2023 the block and tackle for topping lift adjustments were in their normal location at the outboard end of her wishbone. Perhaps as a solution to the increased cosmetic wear on mast ?
Interesting thread… I understand the comment about shorter standing part of topping lift makes reefing easier, since we lift the boom before tensioning the luff.
I do not understand the comment about the Bott sails having their leech cringles set higher. Do these sails have the tack cringles also moved higher or just the leech ? Or maybe the entire sail was optimized with the expectation the reef would be used frequently ? On my prior boats, mainsails were optimized to flatten to de-power and reefing always seemed to be considered an extreme and infrequent option. Maybe flattening isn’t as practical with our rigs and reefing is a better alternative for de-powering ?
I’m very interested to understand the intent of modified leach reefing points so I can determine if the idea has merit for my sailing experience on Long Island Sound. The Bott sails I’ve heard about seems to be optimized for more wind than we generally experience here… but I’m still gathering info.
Captain Greg
Dec 11, 2024, 1:30:16 PM
Hi Rob
Thanks for your response to my post about the topping lift. I appreciate your thoughts. First, a response to your comment about dings and scratches on your mast. These may be from the floating choker block? Mine is encased in a leather pouch which mitigates potential damage to the mast and has worked well over the years. I have never seen a topping lift rigged with lifting tackle as I imagined in my post (i.e. from fore end of wishbone to deck), so I would be surprised if yours had this before, but would be very interested to know if it was…
I can’t respond to comments in another post about the leech cringles set higher, but I can vouch for a reason to raise the boom when reefed. I’ve had the experience sailing downwind in high winds (like when you really need to reef) with the aft end of the mast dipping in the sea when the low side gets extra low. Not a comforting feeling when you consider how much water and weight might scoop into the many yards of sailcloth under the wishbone.
Otherwise… its been a pleasure to read your other posts, seems you have some deep experience in sailing and racing other rigs and you are keen to optimize your Nonsuch sailing experience. Carry on!
I have sent a rigger request to Mike Quill on this issue and will share what I learn with this discussion group.
Misty Cat 26C #121
Nova Scotia
On Tuesday, 10 December 2024 at 09:52:58 UTC-4 Rob Cohen “Soave” NS33 Westport, CT wrote:
Hi Greg,
Dec 11, 2024, 1:53:03 PM
In regards to the floating choker block – Consider an old tennis ball. Quite effective and dirt cheap!!
Dec 11, 2024, 3:02:28 PM
Captain Greg,
I don’t know the length of the standing portion of the topping lift. If you can wait a while I will take a long tape down to the boat and get an approximate length for you. The mast is up so no exact measurement.
When I discussed sails with Botts he said he raised the leech cringle to lift the heel of the boom higher so that it was less likely to drag in the water. The description/explanation Captain Greg gives is exactly in accord with what Botts told me. Raising the leech reef cringle will only work if the corresponding reef tack cringle is not raised as well. If it is raised you simply get a deeper reef with the heel of the boom at the same height above the water. Placement is important because you need correct tension on both the foot and the leech of the sail.
Brian Godfrey's profile photo
Brian Godfrey
<brian@wildbirdshop.com>\
Dec 11, 2024, 3:12:27 PM
This is timely! Any chance of a photo?
The floating block on my choker was leather covered. When we came in from our sail last week my friend was putting out the fenders and came back with a chunk of the leather. The mast is still protected for the time being, but I need to fix this pretty quickly or it won’t be.
Brian Godfrey
Vela, NS33 #77, San Diego
– Brian Godfrey
Brian Godfrey
Dec 11, 2024, 3:22:46 PM
Mark Powers La Reina 26C Vancouver, B.C., INA Nonsuch Discussion Group
I don’t know about the 26, but my owner’s manual lists the size and length of every piece of rigging on the boat (as designed, obviously). I was looking at it just yesterday and it lists all three components of the topping lift: standing part (wire), safety strap (wire), and running part (line). Yours might, too.
And don’t forget the safety strap! It’s the part that catches the boom in case someone accidentally throws the topping lift off of the winch. You don’t want the boom to drop on your head. Your heirs will not forgive you for saddling them with your moorage fees.
Brian Godfrey
– Brian Godfrey
Dec 11, 2024, 3:38:16 PM
Greg,
You are correct… the floating choker block is not present on Soave ! When I expand the diagram in my NS33 manual, I see the block ( if it were present ) would land right where the dings in my mast are.
All season I’ve been scratching my head thinking the choker is way too hard to trim… now I know why. Just in time to add to my list for Santa.
I’ll bring up the location of the reef cringle with my sailmaker, I suspect given my location and proclivity for racing he will recommend the conventional location.
The idea of moving the cringle reminds me of the flattening reef (AKA gentleman’s reef ) used see a lot, but now not so much.
Thanks !
Dec 11, 2024, 5:00:12 PM
The manual does have the measurements for all parts of the topping lift but in the case of my Botts’ sail the standard length was too long. With the standard length the blocks would hit before the boom was high enough to properly set the reef. Another 26 owner in the Toronto area had purchased a sail from Botts at the same time and had the same issue. Shortening the standing part of the topping lift solved the problem. Of course the safety pigtail need to be lengthened. I also have a 4:1 purchase on the topping lift so for each foot the topping lift was shortened I needed 4 more feet of tackle line. I also need a longer leech reef line. It is a nice sail so the changes were worth it.
Tom Schoenhofer 26C#28 North Star Penetanguishene's profile photo
Dec 13, 2024, 12:47:51 AM
Have to add my 2 cents here.
The original 26C #28 topping lift that came from the factory was connected directly to the boom. There was no running part of the toping lift. The PO sailed it this way for 30 years. Makes things simple but is bad for sail shape and with the sail down the boom was at head height to the helmsman and the sail hangars would just clear the hatches.
The Mike Quill topping lift was about 3 feet shorter to make space for the blocks and raise the boom a bit higher. All good.
If you make a new topping lift out of Dyneema and make it the same length as the old one it will be too long. Dyneema has an initial stretch under load as the fibers line up and the splices squeeze tight. Called constructional elongation. After that it doesn’t stretch much anymore. This is called creep. It’s very easy to splice a new eye on deck on the bottom end if you need to shorten it.
26C #28
Penetang
Captain Greg,
Got down to the boat today. It was just light showers so I ran a tape up the mast on a halyard and stretched it back to the heel of the boom. The fixed portion of the topping lift measured between 39’ and 40’. Sorry can’t be more accurate than that at this time. I would go with 39’.
Dec 14, 2024, 6:11:31 PM
Captain Greg,
Please let us know how that length compares to your current toppinglift.
One thing we have not discussed is the concept used on the 324. On the 324 the second halyard is used as the topping lift. As far as I am aware it does not used blocks/purchase but instead relies upon a cabinet top winch. I have not figured out good way to rig a safety with that system. If it is used in combination with a rope clutch it is possible to tie a stopper knot in the line that will hit the rope clutch before the boom comes down too far. It is generally used with polyester or core dependant line. One advantage is that you do not have blocks and tackle slapping the leech of the sail.
I do not have a second halyard so have not been able to try that solution. Bob Neches had a 26 with an aluminium mast and the standard topping lift arrangement and now owns a 26 with a carbon fibre mast that uses a second halyard as the topping lift. Maybe he can provide his views on the relative merits of each system. (Lots of social pressure being applied Bob).
Dec 14, 2024, 8:40:26 PM
Mark,
Ooooh, social pressure. Almost as difficult to ignore as bladder pressure. But that gets us into topics for a very different forum.
I am deeply and truly NOT a fan of having to use a second halyard as the topping lift. I’d love to have it available as a back-up if the first halyard has problems and for sending someone up the mast.
Having to crank with a winch if I wanted to adjust the boom angle turned out to be a lot of work. And, since it’s adjustable, there’s the fear factor that it’ll get loose and let the boom come crashing down on someone’s head.
My first plan for protecting myself from injury if the boom came down was to recruit crew who were taller than me. However, I was told that this is considered ethically improper. (Important lesson here: never tell guests why you invited them.)
So, I had to go to Plan B. What I’ve done is put the same multi-part topping adjustment arrangement as others, then raise the halyard high and use that adjuster for managing boom angle. The halyard runs through a dedicated sheetstopper which has big DON’T TOUCH labels on it, and then is also tied off on a dedicated cleat. I have several cable ties around the cleat hitch which have to be cut off to release it, and more warning labels beside the cleat. There’s also a stopper line rigged from the halyard end to the boom end, so that the boom can only drop so far if the adjusting tackle gets loose.
I never felt that the blocks for the adjusting tackle particularly interfered with the leech of the sail.
So, in short, I’ve gone to a lot of trouble to make my arrangement look and act exactly like the traditional arrangement I used to have on my previous Nonsuch.
Captain Greg's profile photo
Captain Greg
Dec 15, 2024, 11:56:59 AM
HI Mark,
Fortunately it is sunny here this Sunday morning. Misty Cat’s mast is on sawhorses in the side yard. The topping lift wire is 43’-6", so that makes perfect sense compared with yours at 39-40’. Thanks again.
As this vinyl-clad wire topping lift seems to be in perfect condition I may just shorten it to about 39’ and have our local wire-rope loft put an eye in for the adjustable tether and a safety. The manual posted on the INA site shows 31’ for the tether but I’m still considering rigging the load-reducing blocks & tackle between deck and forward end of wishbone, so that would be quite different.
I do have a second halyard (rigged external to mast) and it is invaluable for use as a safety when going aloft, and for the rare times when the primary halyard goes skyward without the sail attached. I would not want to use it for a topping lift.
Misty Cat 26C #121
Nova Scotia
Brian Godfrey
Dec 15, 2024, 3:28:53 PM
With the “normal” (on my boat, anyway) setup of block & tackle at the bottom of a fixed wire topping lift with the line led all the way to the cockpit, the range of adjustment is limited by the length of the topping lift “pennant” (as the running part is called in my owner’s manual) and by the safety strap. You can shorten the standing part as much as you want and as long as you put a long enough line on the running part you can raise and lower it as much as you want.
If you rig that load-reducing block on the side of your mast it is true that it will reduce the tension you must pull by almost half. But you will lose that long, continuous adjustability. Be sure and consider how much line you actually need to pull down with it because once the floating block reaches the deck, it won’t go any farther. I’m not sure how far your boom is above the deck, but for sake of argument, let’s say it is 8’. Subtract maybe 8" or so for the floating block at the top and the turning block at the bottom and you’ve got maybe 7’4" (88") of travel. You could only pull down 88" of your topping lift pennant. If the tackle up on your topping lift is a 4:1, then you will only have 22" of adjustment range on your topping lift. Is that enough?
–Brian M. Godfrey
Tom Schoenhofer's profile photo
Tom Schoenhofer
Dec 15, 2024, 4:05:15 PM
If you still want a saftey just end for end what you have now. The topping lift line now runs over the second sheave and down the mast rather than down the boom. The blocks and saftey strop are at the top instead of the bottom. Now there’s less weight at the end of the boom and less friction.
26C #28
Penetang
Dec 16, 2024, 3:22:45 PM
to INA Nonsuch Discussion Group
The upper block might interfere with the headboard. Also it might be harder to flick the topping lift to the windward side of the sail following a tack. Don’t know if chafe on the sail will be any different.
Captain Greggregcaptain8@gmail.com
Thu 1/30/2025 2:53 PM
I’m opening up this older thread on our topping lifts for an update. Before Christmas I was looking at the best way to convert my fixed TL to adjustable and it was good to have some input from other owners. One of my concerns was how a tackle with a pair of double blocks under variable and sometimes no load can get badly twisted so I was exploring an idea to put the tackle between the deck and wishbone by the mast, rather than above the aft end of the wishbone where it is hard to get at. Since my recent phone consult with Mike Quill I have decided how to proceed. Mike suggested a way to rig the topping lift in the usual postion, but so it won’t twist. I have attached his diagram here, with his permission.
As you can see, the adjustable tether is dead-ended on the port side of wishbone aft casting to an eyestrap. It runs through double blocks at bottom of the fixed TL wire, and at the aft end of boom (on existing TL connecting ring), and a single cheek block bolted into the starboard aft casting of wishbone. This rig should not twist. Other info Mike provided: 41’ length (Nonsuch 26) for the fixed topping lift from masthead (I will probably make it a bit shorter, as discussed earlier, for some leeway when setting reefs). The 3/8" tether is calculated at 65’ but I will measure in place before cutting and splicing the terminal eye. I will add 4 or 5 eye straps along the starboard wishbone tube to manage the TL tether going forward. The length for the safety line will be determined once this is all set up and I think easily made with eyesplices in Amsteel or similar cordage.
Best regards,
Misty Cat 26C #121
BRIAN CAYERb.k.cayer@sbcglobal.net
Thu 1/30/2025 5:01 PM
Thanks Captain,
I will try that when I commission in the spring.
I’m wondering if it being tied off on the port boom would affect the position of the Tl so as you would notice at all when changing tack or jibe?
Brian Cayer
Westbrook, Ct.
For some reason (actually, the Discourse feature of reminding you about related threads), I just get my attention drawn to Greg Silver’s post on topping lift adjuster arrangements.
This sketch looks like a very nice way to solve the problem. One suggestion and one question…
Suggestion: rather than drilling holes to mount additional eyestraps, an alternative is to lash on low-friction rings. This is significantly more expensive, but does save long-term concerns about holes and corrosion.
Question: My current system has a pair of top-and-bottom fiddle blocks, as opposed to side-by-side doubles. I haven’t had any line twisting problems with this setup. However, the inner and outer loops of line through the blocks run closely enough to each other that there is some friction. My blocks are Garhauer 30-01 with shackle at the top, and 30-02 with shackle and becket at the bottom. I know some Nonsuchers use the larger 40-01/40-02 pairing. The picture below shows the alternatives side-by-side. As it shows, it provides more separation between the turns of line.
My question is: does anyone who has that set-up have any comments on how that compares to the one Mike Quill suggested for Greg?
