Has anyone used a magnesium anode for the engine anode in the heat exchanger?
Before there was just a zinc engine anode and a zinc on the prop shaft. Neither seemed to wear out very fast.
A few years ago I switched to a magnesium anode on the prop shaft because that’s what the marina sold me saying they only sell this type now. It is fresh water.
This shaft magnesium anode has deteriorated quickly and needs to be replaced.
However the last engine zinc seems to be like new. It is not a magnesium but rather a standard Westerbeke replacement zinc.
I’m wondering if the shaft anode took all the load and now the engine anode is not doing much.
I see you can buy magnesium engine anodes on line that will screw into the 1/4npt plug the old Westerbeke anodes used. The original zinc is 3/8 x 1 3/4 inches.
https://www.boatzincs.com/engine-magnesium-only-sizes.html
Is there any reason why I should not be using a magnesium anode in the heat exchanger?
26C #28 with a W13
Penetang
