We were experimenting with the reefing setup on my new-to-us NS26 Ultra. After running the 3/8" reefing line through the cringles and hauling up the sail, there seemed to be a significant increase in friction - yes the choker and was loose.
We then added small blocks to the cringles on the leech, which helped slightly, but I’m not keen on the idea of blocks flapping in the wind.
Looking for improvements, my existing reefing lines are old and stiff, so new, more supple lines would likely be beneficial. I’m also wondering if I should switch to a smaller diameter, low-stretch line. Has anyone tried 5/16" with something like Sta-Set? The 3/8" seems too bulky for the job.
Has anybody tried using dyneema for the reefing pennants and splicing it into a standard rope on the deck? This should reduce friction while not compromising grip in heavy weather. My rig only requires a single reefing pennant per reef which I tend to set before leaving the mooring and raising the sail. Since the rig is well balanced, I have never needed to double reef yet. I do use a small block at the tack, but only use the cringle on the roach. Friction is not an issue, even at my age.
Mascouche 26C #1
Definitely you can go down one size with modern lines in all applications these days. I have blocks at the tack and they work well. But I not on the leech, not sure I want them flopping around and besides I have a larger leech. . Some folks are trying friction rings on the leech. I have used dyneema in a cam cleat but in a winch I think you’d need a cover.
John,
Regarding your idea about splicing dyneema reefing pennants. Back when we were racing Flying Scots folks used to make ultra light spinnaker sheets with dyneema cored rope with polyester cover. They would strip the cover off the sail end of the sheet. For the transition you bury some of the cover in the core. ( Here ) is a video showing an example.
Same principle could apply for the reefing line, but I’m not sure I see the need for slippery reefing lines as clearly as other folks.
