I am pretty sure my propshaft is warped. I would like to minimize out of the water time and have a new one fabricated ahead of time.
Has anyone replaced theirs and happen to have the length?
Thank you,
Michael Riley
NS 30C 324, Felicity
Thank you,
Michael Riley
I had to shorten my boats shaft down ten years ago when I converted to Electric Propulsion. Mine was set up for a V drive transmission initially. It was shortened by about a foot in less than a minute using a grinder. You might try and make a ball park measurement and add a little for good measure. You can easily cut it down if needed.
Michael
Do a search of the list. There was a post on “30U Prop Shaft Length” back in 2011. The drawings would be a help because they specify the taper and key ways as well. Maybe George Hite still has them.
26C NorthStar
Penetang
"Mike,
Bill sent the drawings for the shaft. The length is 52 3/4". What a tremendous resource. Thanks again for the lead.
George
On Sun, Jul 3, 2011 at 8:52 AM, Capt. Mike biank...@verizon.net wrote:"
